Back to Basics
Started by Grumpy, August 10, 2009, 09:48:27 AM
sparks
  Bearden's sea of energy does exist and the Universities have verified his claims over and over again working with the Casimir effect.  The vacuum is loaded with oscillations of field polarization but due to the scale of the field and the speed of repolarization the happening is not radiated but stays in the field.  This accounts for the 90percent of the missing mass from the Universe that only radiates gravity and some blackbody radiation and occasionaly a brand new galaxy or Universe.  Mass is pretty well described as a standing wave field.  The only way to convert mass to energy is impose an oscillation into the standing wave field that a either causes a total collapse of the swf which would be bad or b mixes with the oscillations so that the oscillations within the swf couple outside the field. The space the oscillations now reside in is expanded.  This expansion of the field of oscillation alters the time to space ratio needed to contain the swf and the energy contained within the swf is now radiated.  This manifests as the original input frequency diverging into two side band frequencies with the same amplitude in each side band as the original input.  The vacuum oscillations acting as a freely generated intermediate frequency in a superhetrodyne process.  Keelys sympathetic vibrational motor.  Tesla's coax coil capacitors.  Below is how I think I can generate some emps efficiently.  Not really sure at this point what to do with them.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
JesterTerrestrial
Quote from: innovation_station on August 23, 2009, 09:55:47 AM
this all corolates to the charaks ...  the human body and the universal soul ...  when you get into ballance you will be able to love....
Hey IST!
Hanging at the Innovation Station got me all fired up to use my
I - MAGI - NATION ;D
I wrote you all a little story...with pictures.
That should help you get back to basics!  ;)
Have a beautiful day in the diamond sea of aether!!!  8)
Its good to be ABLE TO LOVE
http://www.projectavalon.net/forum/showthread.php?t=13463
Grumpy
Conduction and Displacement Current in Capacitors
http://www.itee.uq.edu.au/~aupec/aupec04/papers/PaperID84.pdf
Establishment of Magnetic Fields in Coils
http://www.itee.uq.edu.au/~aupec/aupec04/papers/PaperID85.pdf
EDIT:
Excerpt from the second document:
QuoteWhen the inwardly propagating wavefront H2 reach
the magnetic material the H field falls to almost zero,
and the wavefront is reflected off the surface of the
core back towards the coil as shown in Fig 8(b). The
surface of the core is a magnetic short circuit and
behaves like an electrical open circuit. Thus the
direction of the H field is reversed by the reflection
while the E field is unchanged. As the reflected
wavefront moves back towards the coil it cancels out
most of the original H2 field, so that the resultant field
inside the coil is very small, as indicated in Fig 8(c).
Some may recall that the COMP pulse is "nulled" by ferromagnetic materials.  this reflection probably has something to do with that.  This initial reflection may not occur if the ferromagnetic meterial is already magnetized.
        -Frank Edwards
sparks
   Could a dc current create a vortex field around the conductor.  The spiraling dependent on low to high pressure gradients of the electric field.  As the charge carriers move through the circuit they stretch out the vortex until it appears tubular.  Loop the conductor and the tube becomes torroidal  Pump up the loop current and the torroid becomes spherical.  Neat website does a better job at explaining this then me.
      http://www.singularvortex.com/UVS%20on%20geometrical%20structure%20of%20magnetosphere.htm
Think Legacy
Spread the Love
Grumpy
"A spinning E field is equivalent to an electric displacement current."
"It follows that an electric field E, moving sideways, is wholly equivalent to a magnetic field, B."
http://arxiv.org/ftp/arxiv/papers/0801/0801.4688.pdf
"The subject paper, which will be reproduced later in this Report as Appendix II, explained how radial electric displacement, as opposed to the transverse displacement we know from Clerk Maxwell's theory, can induce `vacuum spin' or `aether rotation' which permits such energy densities to be stored in an electrically quasi-stable manner at low voltage gradients."
http://www.aspden.org/reports/Es8/Rep8.htm
        -Frank Edwards
