Back to Basics
Started by Grumpy, August 10, 2009, 09:48:27 AM
BEP
Quote from: Mannix on October 06, 2009, 12:36:42 AM
So the movement is what generates the energy?  that would explain the cork , and the bath tub voilence.
so how to get the movement ?
If you pass current through a wire that is already in a magnetic field that wire will move.
If you move a wire within a magnetic field a current will be induced in that wire.
wings
Quote from: BEP on October 06, 2009, 07:19:11 AM
my suspect if you pass a step pulses (or train wave that have fast "group velocity") in the wire you align the spin in the wire and you have gyromagnetic effect "Barnet effect" or "Einsten De Haas effect"
Grumpy
Quote from: otto on October 05, 2009, 11:48:40 PM
Hello all,
@Grumpy
you said that the vibration is just a secondary effect.
Secondary effect of what?
Can you imagine this could be the main, the most important effect?
@All
Im not so clever as a lot of people here are, so maybe somebody could  explain me what happens during 1 kick in a coil?
Is this the basics? Yes.
Otto
The "energy" - call it longitudinal, companion, aether flow, any term - has "momentum".  So, the vibration is a secondary effect of the "energy" propagating (moving).  This momentum is somehow related to the interaction of the fields that cause the "energy" to manifest.
In the "bathtub experiment", I can only assume that there were a series of explosions as the TPU tried to compress or expand the water.  When water is used in capacitors, after a short time it will dump all of the energy spontaniously.  This is why it can be used in pulse capacitors, but only if you follow the paramaters.
Cork is elastic.
        -Frank Edwards
Grumpy
Quote from: otto on October 06, 2009, 12:52:35 AM
Hello all,
@Mannix
first we have to know what happens with our kicks in the coils:
We have an action - a kick
Then we have an reaction - the collapse
What effect is stronger? The action or reaction?
The movement is not a problem.
Otto
When exploding wires, the compressive force is thought to be much stronger and thick pipes have been exploded with a negative pulse into a small wire inside the pipe.  The positive pulse causes an expansion and is not this powerful, in this case.
When you first "kick" a coil, all of the parameters of the system have to adjust.  This is not instantanious and takes intervals of time.  When you place 10kv across a piece of coax, it take a few seconds for it to "adjust", and it makes a cracking sound. Same thing when you discharge it.
Do doorknobs and plates charge/discharge faster?  Yes.  Replacing coax with a tube inside a tube of the same length will might work better than coax, but still maintain the reflection to turn off the switch.
When you first "kick" a coil with low self-capacitance, high self-induction, and no ferromagnetic material for the energy to perform work on, a shockwave is created in the space around the coil by the sudden change in polarization.  I always thought that the "mass" connection to this was bullshit, and that surface area was the real reason, but now I believe it is the mass.  It is the "mass" adjusting that creates the shockwave.  The wire does not explode because it wants to, it explodes because it has to.
One large kick can ruin your day, but one small kick doesn't do much.  However, the system takes time to adjust, so consecutive kicks can accumulate.  You can read about a similar effect on transmission lines in many of Steinmetz's lectures.  Basically, if you add energy to a system faster than it dissipates, then the energy accumulates.
Put a plastic plate or sheet over a coil while you pulse it and then touch the plastic.  There is no arc or spark going through the plastic but it will hurt like hell to touch it even if it is 6mm thick.
        -Frank Edwards
otto
Hello all,
@Grumpy
I have a vibration but NOT a moving of any "energy" because I dont have a TPU connected to my little transformer.
Otto
