New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
winsonali
its uploading as soon as its finished i will post the link here may be 1 hour more
minde4000
I am sorry sir. I have had there issues before I tought that was the case. Didnt mean to rush or anything.  :-X
EMdevices
Ali,
I see only one video under your name at www.you-tube.com, where did you post the second one?  (P.S. ok I just read the above comments, I'll wait)
I watched your first video again, and listened to what you say and also what you just wrote, and I have a few more comments:
1)  Your input stage to your device seems to be a VOLTAGE MULTIPLIER using only capacitors and diodes, it uses 3 capacitors (seen in the video) to increase the voltage by a factor of 8=2 x 2 x 2 This is the ideal multiplication factor when no current flows, but if current flows due to a load, the multipliers have a % regulation factor, and the output voltage drops somewhat from this maximum voltage.  These voltage multipliers don't need inductors, like you claim in the video.    Here's a link for the interested folks:   http://en.wikipedia.org/wiki/Voltage_multiplier
2) From you performance ratings  (30 V input to 220 V output,  and 49 V input to 338 V output) I see you have failed to provide voltage regulation, like your friend asked you too.  Voltage regulation means you maintain the output voltage at the desired level despite fluctuations in input voltage or load.
3) Good look with your DC input design.   This should be easier to prove if its free energy or not.
EM
minde4000
It says video has been removed because it was too long :)
Minde
