New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
markdansie
@Lucian
Just to clear up some confusion you said:
"The type of Moraru Engine which I have "replicated" , produces 117 times more energy than it consumes, and my model is not the most improved made by Moraru... "
Then in a latter post you said you diD not measure your device with instruments?
Just for your information , Ali has generously allowed his device to be tested by a qualified physicist and electrical engineer who are assisting him with advice and accurate measurements. This is a testament to Ali's belief and honesty. I am wondering given your statements above if you would be willing to have your device tested? I might add that Ali has been offered support by many good people and so far no one has attempted to suppress the technology.
Once again markdansie@bigpond.com
Kind Regards
Mark
Lucian Stefan
There is no confusion. Somebody asked me if the Moraru magnetic motor has been tested by an independent person, I'd answered "no", but "I have nou doubt BECAUSE EVEN WITHOUT ANY CONTROL APPARATUS IS CLEAR that the Moraru engine generates more than it consumes". That's what I've said...
Nicolae Moraru was been inventor and scientist, professional research-engineer. About Ali, I not wish to delete your hopes or your private beliefs. Assuming that there is an invention, if Mr. Ali wish to publish his invention, he is free to do it. Ask him his wonder device and you'll have the O.U., isn't it ? Simple.
Moraru Magnetic Engine is not to be published; Nicolae Moraru didn't published, I keep his desire. The only public patent is the RO 109405 and I have already post it.
markdansie
@Lucian,
Hi, firstly my appollogies for not expressing myself well.
I was referring to your replication. Are you willing to have that tested ?
Your Quotes:
"For me, it is simple to use their documents and my small demonstration device.
"The type of Moraru "Engine which I have "replicated"
In the case of Ali, time will tell, but at least he is working with others on establishing correct measuring procedures.
Kind Regards
Mark
teslaalset
Although Ali mentioned he is not using any coils, transformers or magnets, if you look to electrolytical capacitors they are not ideal capacitors.
They have a resonance frequency at several 10KHz where they act as very low resistors. e.g. a few tens of an ohm.
An example of a replacement diagram for these capacitors is attached.
The leakage resistor is normally a few 10K ohm, which is bypassed in case resonance.
The coil value is normally a few tens of nanoHenries
Since it looks like Ali uses 3 big electrolytical capacitors, there will be three different frequencies that correspond to these three capacitors, due to tolerances. Maybe he uses this some how.
tagor
Quote from: Lucian Stefan on September 27, 2009, 05:43:28 AM
Hi,
I know the content of rex research file, because... I posted it there.
You can find there also an old article of "Science et Vie" no.700/Jan. 1976 (when Michel Meyer was 22 Yo.). In the experiments described there he used copper as extraction material with the apparently efficiency of 30-40 and the real efficiency less than 10^-6.
There are also another documents and studies about the same principle.
In the attachament, the cover of Science et Vie no. 700/January 1976, the interesting article at pag.42-45, at "Physique" box.
you can read this article here ( in french )
http://franckvallee.free.fr/localhost/plain/content/download/137/535/file/Science%20&%20vie.PDF
i spoke a lot on this in this thread , in french
http://www.overunity.com/index.php?topic=4744.msg99000#msg99000
but in this thread , in english
http://www.overunity.com/index.php?topic=1310.msg93301#msg93301
a lot of replicators , but ...
nothing ... no OU ...
