New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
jan.kolar
There is very good explanation of mechanical siphon on wikipedia (http://en.wikipedia.org/wiki/Siphon). Nothing mysterious here, energy conservation law is perfectly valid. Here is short extract from article mentioned:
"The velocity of the siphon is thus driven solely by the height difference between the surface of the upper reservoir and the drain point. The height of the intermediate high point, hB, does not affect the velocity of the siphon."
Its strange that Ali is so emphasizing analogy with mechanical systems:
"mechanical example of situation: you have bath tub full of water the top is open water cannot flow
out from top if you make a whole in bottom of the tub it will flow (natural) now i have to make
water flow from top. if i can do the same in electronic means what i have achieved is creating PD
with non aligned electrons." (September 1, 2009, 7:23 AM)
"we need to think out off box , if you can explain electricity mechanically you can treat it like that" (September 11, 2009, 4:25 PM)
I dont know about mechanical perpetuum mobile or overunity device based on siphon effect. If Ali's analogy is valid then no problem for him to build also mechanical device with closed loop running indefinitely.
jan.kolar
Quote from: allcanadian on October 16, 2009, 11:37:21 AM
@jankolarMost often the difference between the possible and impossible amounts to nothing more than knowledge and understanding. Inductance acts like the mass on a pendulum displaying the property of momentum. Do a little experiment for me and yourself. Attach a mass(inductance) in between two springs(capacitance) or elastic bands then attach one end of this apparatus to a wall or doorknob. Now, hold the other end of the spring and start pulling and releasing the spring so that your pull/release is in time with the motion of the mass, this is resonance---note the frequency of your pull/release. Now double the weight of the mass and try it again, you will find the frequency has changed. In order to keep the frequency at it's original value of the smaller mass you will have to pull harder and faster on the larger mass---extra work. The power grid in North America is locked at 60Hz so you cannot change the frequency, when inductive loads are attached that are not resonant at 60Hz extra work(current) is required just like in our little experiment. Instead of doing extra work you can change the stiffness of your springs(capacitance) to compensate for a changing mass(inductance), the resonant frequency of the load can then be matched to that of the source (resonance), this is PF of 1. The reason few people utilize PF correction equipment is because it involves high power/high speed electronics usually, this is very expensive. The fact of the matter is most people are ignorant to the facts or they just don't give a damn, ask your self why almost nobody here understands what PF is or how it works? I have one simple rule----- If I don't understand something--anything, I research and experiment until I do. Very simple concept.
AC
You have quite a good vision of what PF is. You are right that more power is needed if electric circuit is not compensated. But this more power is almost immediately returned to grid. Its like short-term loan. This part of electric power is called reactive power and as I know it is not measured by conventional electric meters. Check this:
jan.kolar
To make it even simpler. You need some energy to charge a capacitor, but this energy is few miliseconds later returned to grid, when capacitor is discharged. So if you disconnect your simple circuit with only one (ideal) capacitor in right moment, you have not consumed any electricity. The similar reasoning is valid for inductor. This is reactive power. Capacitor has negative reactive power, inductance positive reactive power. Reactive power can be measured by special electric meters (var meters).
Real power represents the losses on resistors in circuit that are transformed to heat + mechanical power (if you have electric motor).
winsonali
hello everyone,
i am now settled in my new premises and now up and running once again
i will be posting new video showing use of digital watt meter/hour  that can show us exactly the watt frequency and power factor
after limiting the input current and putting a digital watt meter hour on input and output has given a difference of 80 watts gain
input is 96watt what device is taking and out put is 176 watt going out from device
i will post the video shortly
results are good and i have got another project to do not related to alternative energy but very interesting jamming digital video reception producing water marks that are not visible with naked eyes but if a camera takes video or snap it will appear and will distort picture. this new project is a new jewel in my research carrier
thanks every body
teslaalset
Hi Ali, good to see you back in this forum!
Looking forward to see your 3rd video on power amplification.
The company I work for has done quite some research on your new project and obtained some essential results and patents. If you are interested in their technology just PM me, I can arrange some info on that.
To be honest it's quite hard to understand why you pay attention to new subjects while your power amplification project seems so important for the world.
