New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
winsonali
 wattsup
thanks for understanding
i am just working for the input of genie the output of genie is just like any inverter so it can not be feed backed
i have tried all only possibility with out a dimmer is a transformer based circuit then we can feed back. Everything in this world has its limitations
during the course of developing that input feed i decided to try different things so i am doing this and i hope with the support and knowledge base coming from forum and my own ingenuity i will achieve the target soon. Some adverse comments from member of the forum is the price of knowledge we are gathering
still i am thirsty for my quest regarding magnetic fields and their effects
winsonali
wattsup:
thankyou once again this link is very usefull and full of knowledge
others should also read that link
FatChance!!!
Quote from: wattsup on November 13, 2009, 12:50:54 PM
What the hell are you guys talking about. Since when is a center of two series batteries a zero point. Maybe in your dreams. If DC was so alike AC then Tesla would have been out of business since day one. In AC both outputs fall to zero at the same time, then go back up to maximum on the reverse side and so on. There is no positive and negative. lol
You are wrong and I'm sorry to shatter your missconception on AC vs DC with a midpoint.
Using two batteries or any other DC source where you are shifting the polarities by electronics
will create an output just as you say where "both outputs fall to zero at the same time".
The midpoint mentioned is simply the level where the output meet each other when they have fallen.
This is regular knowledge and produced by all analog amplifiers in every TV or Stereo.
The shape, rise/fall time determines whether the AC is categorized as Sinus, Square or Triangular wave.
The simplest way to create AC from a single DC source (no midpoint) is using a bridge connected
power amplifier where the input is 60Hz and 180 degrees shifted sinus from a frequency generator.
Then connect your device right between the outputs and you have your own AC source that is
totally adjustable both in frequency and voltage.
jan.kolar
I think we should recapitulate some basic theory of electromagnetism. We should distinguish between electric potential and electric voltage. These are two different things. If we are talking about electric potential then we should know that choice of place with zero potential is arbitrary!!! So it doesnt matter if we choose zero potential in central, bottom or top wire. Electric voltage which is potential difference will be the same in all three cases. I agree with FatChance!!! and Stefan that if we want negative&positive voltage at the same time then reference point should be in center (provided that we are using two 12V batteries). The negative voltage we obtain in bottom wire is principally the same we could get from grid (neglecting that AC is time dependent and changes polarity 50 times per second). No new quality if we use negative voltage from grid its the same as from battery.
winsonali
i am so dump i never knew this is so simple that we set the reference zero by ourselves and can set it any where
i wish this knowledge will lead the power supply manufacturers and they stop using 79XX as negative regulators and circuit designer start using this techniques as mentioned in earlier posts
