New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
winsonali
i have just made a diagram to understand the +VE and -VE supply difference i think this a practical approach
Groundloop
@winsonali,
If you want +9VDC and -9VDC with a common ground then here is how you do it.
Groundloop.
tinu
@winsonali,
OMG!  :o
Is it so?!
Why did you turn the second battery up-side down?! Is it lead-acid? Be aware, it may leak on the floor etc.  ;)
Wouldn't be better to keep it the way producer recommends?  ;D
Ali, Ali, I don't get how possibly you could master electronics the way you do if a simple AC signal slips through your fingers!
winsonali
i agree with most of the ideas i am working hard to develop some supply that can replace dimmer
Groundloop
@winsonali,
If you want to run your circuit from a battery(s) and need 230VAC clipped via a triac dimmer
then use a true sinus 12 (or 24) volt unit that converts the battery voltage to a true sinus
AC voltage. Connect a triac dimmer on the output of the converter and you have what
you want.
Groundloop.
