New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
winsonali
any way the point is not what and how supply connections are right or wrong
the main problem i am facing is when i try to produce grid like power out put
from transformer we can easily produce +ve and -ve DC supply now the main thing is to combine them on single wire with on and off period of 50 HZ but for 2 milli seconds only during each cycle when we turn on NPN mosfet to pass +ve volts it also go to PNP mosfet for negative supply and that blow up immediately
i am working and will solve the issue shortly well thank you for your help.
Groundloop
@winsonali,
Can you make a drawing of you problem? A drawing makes it easier for me to understand
what your problem is. I may be able to help.
Groundloop.
allcanadian
wattsup
@winsonali
So in essence you are pulsing in reversing polarity at 50hz with 2mS on time per cycle. If you are switching this on one wire, would you not then need the same switching on the other end of your circuit in reverse otherwise you are just making a short circuit. Unless if the shorting is desirable.
If anyone here can help you it is most certainly @groundloop. You can count yourself lucky for him to extend a helping hand.
quarktoo
Is he trying to build a simple H-bride circuit or figuring out that a resistive load such as a lamp is dependent on voltage ?
http://www.mcmanis.com/chuck/robotics/tutorial/h-bridge/
Kind of reminds me of hydrocars claiming a free energy device after he discovered that you could charge a cap and the increased voltage would make a light bulb work.
