New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
0 Members and 108 Guests are viewing this topic.
Groundloop
@winsonali,
>>the circiut designed by ground loop is basically flip flop AC which changes the positive
>>and zero between 2 wires this technique is used in SMPS inverters and they work
>>very fine but there is no below zero  reference in there.
I do not agree with you. The circuit I have designed can generate a signal that is
like your chopped up sinus input. Providing the circuit has an input as described in
the drawing. It has nothing to do with a basically flip flop AC. The circuit is analog
and can be controlled so that the output is a analog sinus.
Does your circuit use a two wire input or not?
BTW: My nick is Groundloop!
Groundloop.
winsonali
groundloop:
may be i have used the wrong term FLIP FLOP my knowledge is not so good in electronics as yours or  others on the forum i am just learning
In your circuit the timing sequence of each Opto coupler can be set and we can get any desired frequency and duty cycle so it means we can develop variable RMS voltage regulator through software and just getting the feed back loop in we can adjust load and current as well ......
so you are right i have designed the same type of circuit using IRF 3205 which is 55 volts 110 amps
lets see what results comes out when i will get the PCB
thanks
Groundloop
@winsonali,
Could you PM me an email address I can reach you on?
I have a lot of designs that may help you in your research.
Groundloop.
powercat
This is looking like a very promising team ;D
With all the fantastic work Groundloop has done over the years, I don't know why he is not an elite member yet
cat
