New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
winsonali
BEP:
Quoteexperts opinion bring worth and knowledge hidden in their experience of years
very simple question to all forum member
mechanical converted to electric energy by magnetism(electro + permanent)
it means they are from the same origin they speak same mother language
Now
1) if DC batteries are connected in series, that perform addition(1.5V+1.5 V=3V), what happen if we connect magnets in series?
2)  2 DC batteries 12 volts and 6 volts connected in parallel ? voltage level remain same but current increases,what if we get magnet aligned in parallel?
thanks
wattsup
@winsonali
In one of your previous posts you said "comparator" and that made me think about a device I used to sell in the 80's called an Electronic Power Factor Controller. We had models able to control up to 200hp motors. The device basically senses the load on a motor and provides only the power required to run the load requirement by cutting out a portion of the sinewave. The three patents on this is located here and may give you some ideas on how to better use Triacs. The NASA folder holds the original patent that was then licensed to manufactures at the time, but I seem to see know it is completely forgotten. I should have held on to my last units.
http://purco.qc.ca/ftp/Companies/Cynex%20Manufacturing%20Corporation/
Nihilanth
Quote from: winsonali on November 20, 2009, 05:18:25 AMcan you send me some useful links i need mechanical  energy conversion formula's linear force vs circular movement and i think its your  field
You're planning on implementing mechanical parts into your device? :(
"I think it's better to have ideas [than beliefs.] You can change an idea. Changing a belief is trickier. Life should malleable and progressive; working from idea to idea permits that. Beliefs anchor you to certain points and limit growth; new ideas can't generate. Life becomes stagnant." - Rufus the 13 Apostle.
winsonali
no its for comparison and paper writing about the device and its efficiency over different form of energy conversions techniques
CompuTutor
Quote from: wattsup on November 20, 2009, 08:26:47 AM
.....a device I used to sell in the 80's called an Electronic Power Factor Controller.....
On that...
Is there currently a company
or brand on the market now
that you can recommend?
(Less then 2-HP motors)
Sorry for the off-topic question,
it was thrown out there though.
