New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
winsonali
during my recent working i have established this fact
a magnet either permanent or electro has nothing to do with electricity generation its just a property of materials to attract like materials and the reason is polarization this means it has fixed exit and entry points .
the mechanical analogy is, if you have cup of tea and you want to mix sugar in it, now you will use a spoon if you just put the spoon in the tea it will not do any thing, to mix the sugar you need to stir spoon this means you have transfered the ME energy in system
like wise a magnet can not induce current in a coil just by keeping it near to the coil, it will transfer ME energy in coil when you move the magnet this means ME is transfered in electricity and the media used for transfer of energy is magnet.
magnets work as carrier of energy waves from ME to EE also, EE to EE ( open loop transformers, charges travelling in vacuum )  mean while if we intercept these waves and modulate them on another field you will get added energy of magnetic property.
the important thing is charges travelling should posses less energy then intercepting field force in vacuum.
mechanically this is not easily possible because you need 120,0000 RPM for proper modulation but thanks to modern power electronics we can simulate this in electronics
teslaalset
Quote from: winsonali on November 17, 2009, 01:39:48 PM
a better understanding of Ac current can be visualized by this animation
Tesla win the war of currents
nature has created one type of current that is DC produce through chemical or light or even thermocouple
man created or simulated AC current to use it for ease and portability
my next video shortly show all forum members the self running unit....
Is there any progress on you new video, Ali?
We are all quite curious and looking forward....
winsonali
yes shortly
in my last post i have given a clue how i am doing electricity generation
gyulasun
Quote from: winsonali on November 20, 2009, 08:24:35 AM
very simple question to all forum member
mechanical converted to electric energy by magnetism(electro + permanent)
it means they are from the same origin they speak same mother language
Now
1) if DC batteries are connected in series, that perform addition(1.5V+1.5 V=3V), what happen if we connect magnets in series?
2)  2 DC batteries 12 volts and 6 volts connected in parallel ? voltage level remain same but current increases,what if we get magnet aligned in parallel?
thanks
Hi Ali,
Nobody reflected on your questions so I try to answer them.
1) if you connect two magnets in series like NSNS I think you get a stronger magnet, about twice as strong if they are of the same strength each. Their Bloch wall will develop in the middle of their full length as if you had manufactured the double length magnet immediately, instead of the original "half" length
2) if you connect two magnets in parallel then normally you have to use soft iron yokes to guide the repel poles so that you could handle the parallel closeness, this way you can also add up the fluxes of the individual magnets, see Joe Flynn's parallel path technology for instance.
One notice on connecting a 12 and a 6V battery in parallel: you cannot do this directly because the higher voltage battery will be loaded very heavily by the lower voltage one and the former gets discharged very soon and the latter will be heavily overcharged. Normally such parallel battery combinations have no much sense, and even in case of similar voltage batteries a series diode is used with each battery to prevent any harmful influence on each other.
rgds, Gyula
teslaalset
Quote from: winsonali on November 22, 2009, 12:44:23 PM
What kind of vacuum are you actually using?
Vacuum tubes? Can you mention a type number?
Your cryptic description reminds me also of light travelling at different speeds in air, glass, water....
