New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
winsonali
gyluasun:
in my experiments  i have got these results
2 magnets in series means single magnet of the same strength as single one just the length is increased
adding 2 batteries of 6 volts and 12 volts you are right we need to protect the low voltage battery from over charging
in new devices various channels are operating producing different voltages we need to collect all spikes and produce collective energy.
forest
seems that if on primary side we do not use all energy which is there then when  secondary is loaded that hidden energy contradicts power on secondary - Lenz law
when we use all energy available in primary - both electric and magnetic part converting to one kind then on clever made secondary we can multiply primary power many times
i'm not sure about that but it seems quite possible that electric power has both magnetic and electric components and both are equal and opposite exactly like Don Smith states
the key is to move both components from primary to secondary and secondary becomes a disruption of ambient field which respond to equal power all around which can be collected in multiply
gyulasun
Quote from: winsonali on November 22, 2009, 03:44:21 PM
gyluasun:
Ok on your series magnets, I can accept that because personally I have not tested it (only the parallel case), sorry for this, and I answered what I read on different forums, probably those writing the double flux for the series case did not test it correctly before or were mistaken.
I can imagine though that the flux of two seriesly joined magnets may become a little more concentrated at the ends but this multiplier cannot be the double value of one magnet but a value between 1 to 1.4 maybe.
rgds, Gyula
winsonali
FOREST:
Quote'm not sure about that but it seems quite possible that electric power has both magnetic and electric components and both are equal and opposite exactly like Don Smith states
you are right electric power have both component magnetic properties  and electrical but they are not opposite to each other
copper is not attracted towards magnet, make a coil and supply power to it without any core inside coil ,you will see it will show magnetic property by attracting iron pcs
on the other hand take a magnet pure and check with you multi meter you will find high resistance in magnet although it is made up of iron.
magnetic and electric charges are not opposite to each other
please check the voltages produce when you move a magnet over the coil you will find they start as magnet move towards the coil and finishes as magnet go away from coil, if they were opposite they should behave vice versa
jan.kolar
I see that this thread is leading nowhere. Ali, how can you talk about magnetic charges? No one has ever seen magnetic monopole and according to classic electrodynamical theory they dont exist. If you discovered magnetic monopole then you deserve Nobel prize. But more probable you dont know what you are talking about. Have you ever seen Maxwell equations?
