New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
gravityblock
I believe Ali is talking about extracting energy from the zero point field which will propagate through space and can be picked up by many receivers.
Electric charges follow the path of a wire which will always remain in the active zone.
Magnetic charges can enter the passive zone since they don't have to follow the conductor, they will follow the electromagnetic waves which propagate through space and can be picked up by many collectors in the passive zone to complete the energy transfer.  As the receivers collect the magnetic charges, the magnetic charges will be replenished from the magnetic fields propagating through space without affecting the source since the source isn't using any net current.  The source only requires a voltage to extract energy from the zero point field.
Please correct me where I am wrong Ali.  I look forward to the video of your latest device.
exnihiloest
Quote from: winsonali on November 24, 2009, 06:30:32 AM
process of PM manufacturing is based on cooling the material slowly/naturally in magnetic environment
Bullshits.
PM are made at room temperature from magnetic materials placed in pulsed magnetic fields generated from coils powered with capacitors banks.
exnihiloest
Quote from: gravityblock on November 23, 2009, 05:50:03 PM
Magnetic monopoles detected in a real magnet for the first time, http://www.physorg.com/news171209923.html  Also, according to the article they interact in the same way as electric charges.
There are serious doubts about this article. The extremity of a long solenoïd (L >> r) carrying a current is similar to a magnetic monopole. We can guess that pyrochlore-lattices provides such long chains. Without confirmations from independant teams we can discard this pseudo-discovery.
jan.kolar
Quote from: exnihiloest on November 25, 2009, 02:57:21 AM
Bullshits.
Ali do you know what hysteresis curve is?
CompuTutor
Quote from: jan.kolar on November 24, 2009, 04:55:47 AM
Ali, Ali you have not heard about law of energy conservation? Yes you can have 100s of receivers but signals on input antennas are very small typically microvolts. Also there is feedback between receiver and transmitter similar to coupling between secondary and primary side of transformer (Lenz law).
If it was that easy,
then TV and radio would have viewer/listener meters
instead of nielson programming rating boxes...
I for one would gladly show them I block each and every commercial
so they would see that ancient business model doesn't work anymore
(No matter how much louder than the programming they make them!).
however sympathetic vibration is a huge deal with this whole thing.
Surely no one disagrees with that?
I mean, are we sure that Tesla wasn't simply setting up a sympathetic vibration with his amplifying tramsmitter so our enviroment (Earth/ionosphere) could easily tap what has always been there in the first place?
8) Sits and awaits the flames from the usual Tesla nay-sayer's >
