New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
jan.kolar
Quote from: forest on November 26, 2009, 08:38:37 AM
Can you point me to the articles explaining exactly what is happening in LC circuit at resonance   ? And I mean where is the energy in each part of period of oscillation , not just equations.
In resonance circuit behave as pure resistive (mathematicaly this can be expressed as imaginary_part(impedance)=0) even when containing inductors and capacitors. So there isnt phase shift between current and voltage. Energy of magnetic field of inductor is cyclically transformed to energy of electric field of capacitor and vice versa. So energy source supplies only losses in circuit.
winsonali
EMDevices:
hi welcome back
after completion of genie circuit we are replacing dimmer from genie input
as a replacement of dimmer i am developing a power supply to provide 40 volts in both polarities on the same line with very low duty cycle. during this process i have develop this new method for power transformation its a transformer where center pole is replaced with as vacuum tube. i am trying to use the properties of passive zone actively. once this section is completed we can make a self running unit.
Forest:
1/4 wave length means completion of one quadrant
magnets create a fields in vacuum but have no frequency so they act like a, living black hole, for there like materials and try to absorb them if you change there polarities quick enough it will create moving charges and if these charges provided proper gate they leave there active zone to passive zone
proper gate means a conductor equal to the wave length of frequency or 1/2 or 1/4, on each 1/4 wave length energy change its direction
at 1/4 wave length one end of conductor act as negative pole and 2nd end become positive pole and vice versa so every 1/4 time of the frequency a wave dissipate it self and enter in vacuum.
conventional transformers never complete this level so they receive a kick back BEMF.
wattsup
winsonali
wattsup:
wonderful i never knew about such things before
the concept here is almost as i am using with one difference that we are using coils around tube to catch EMF due to high frequency at the closest possible proximity.
you can develop your own Vacuum tubes use glass tube and seal the end using epoxy put a rubber valve in it and suck the air out.
my experiments are going well and just finishing the last bits and pcs how wonderful it could be if overunity.com  can host videos as well.
wattsup
Quote from: winsonali on November 27, 2009, 01:24:16 PM
wattsup:
Yes I realize that is what you are doing. Why the hell not. With all that tube plasma activity, there is bound to be some potential to capture around it, in what form I do not know. lol, but as that coil will get loaded, it may then effect the tube function itself.
