New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
jan.kolar
Quote from: onthecuttingedge2005 on November 30, 2009, 03:01:39 AM
I remember a lecture done on Tesla strength almost two decades ago, they said that at or above 13T some forms of matter began to act like liquids instead of solids. but 13T was the beginning of that magical tesla number.
I have never seen that phenomonom directly because I have never had access to a Super Electromagnet of that strength. I have heard that we can acheive up to 900T pulsed for less than a second but the device destroys itself in that brief moment like it was a box of dynomite. nobody at all is allowed to be in the room when they charge it up or they would die.
In magnetic resonance imaging field strength used is commonly 1 - 2 T. Negative effects on human body are not recognized but attention must be held to remove all iron things apart because in field of this enormous strenth they would be accelerated like bullet from rifle. Of course another situation is with alternating magnetic fields.
Quote from: jan.kolar on November 30, 2009, 05:48:22 AM
In magnetic resonance imaging field strength used is commonly 1 - 2 T. Negative effects on human body are not recognized but attention must be held to remove all iron things apart because in field of this enormous strength they would be accelerated like bullet from rifle. Of course another situation is with alternating magnetic fields.
at 13T and above I think that unlike Iron even Pepto Bismal in the body would be a deadly interaction with such a field strength.
at around 100T it wouldn't matter because every element in your body would be influenced terminally. Paramagnetic, Diamagnetic, Ferromagnetic, ferrimagnetic, Anti-ferromagnetic, and so on would be highly effected.
winsonali
my latest experiment is very successful
only thing left is power regulation
because their is only one coil that is the secondary coil is present in the system so it will get the maximum power now either i have to create different tappings or some other digital format like change in duty cycle to control output power
Nihilanth
"I think it's better to have ideas [than beliefs.] You can change an idea. Changing a belief is trickier. Life should malleable and progressive; working from idea to idea permits that. Beliefs anchor you to certain points and limit growth; new ideas can't generate. Life becomes stagnant." - Rufus the 13 Apostle.
winsonali
Finally, over half a century after Einstein made his contributions of general and special relativity, Myron Evans, following in the tradition of Einstein, accomplished the impossible.
Instead of trying to quantify gravity in terms of discrete packets of energy (quanta) to make it comply with the standard model, Evans took the opposite approach, He succeeded in describing the standard model in terms of geometry. In the Evans Grand Unified Field Theory (now called Einstein Cartan Evans (ECE) Theory - MWE), particle exchange is not the fundamental unifying factor. Instead, for each force there is a specific curvature of spacetime or spacetime geometry. The resulting equations can be applied to any area of science and engineering. The impact on the computer, transportation, medical, power, and manufacturing industries will ultimately be as profound as the discovery of fire."
