New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
aaron5120
Quote from: winsonali on December 20, 2009, 09:32:15 AM
aaron
just send me the address i will send you the programmed IC there is no cost for IC
if you are seriously working towards solution its my responsibility to support you.
Ali
Hello Winsonali,
I have already sent you my address. Please check your personal mail box here in the Overunity Forum.
Thank you for your help, may God bless U.
Aaron
winsonali
aaron:
i have dispatched the IC to your given address
enjoy ;)
EMdevices
In the Steron video, they are using the toroids and saturating them at the correct time.  The cycle goes as follows:  the magnets attract to the cores when they are not energized (since it is a magnetic material) and after they rotate into position the cores are magnetized into saturation with DC and the attraction between the magnet and the core is now weaker, so as a result, the retarding force is now weaker then the previous attractive force, so a net imbalance in forces is created, hence you have a motor.
This type of motor is nothing new and it is not over unity by any means.  It is just an unconventional motor that never found acceptance due to it's poor performance (weak torque, low efficiency).   I get sick of all the people who think they have something or discovered something amazing and in reality they expose how little they know.  These guys might want to read up on steeper motors, they have a hell of a lot more TORQUE
I see some of you talk about breaking Lenz's Law and I think most people have the wrong impression about what it is.   All lenz's law states is that the polarity of the voltage induced by the changing magnetic field is OPPOSING the applied voltage, it is simply analogous to the inertial force that always acts against the applied force.  Without inertia you would not build up momentum or energy, same with electricity.  If you don't have this effect it means you're not building up a magnetic field, which contains energy.  Some people build bifilar coils and claim they have broken Lenz's law, when in reality they have a poor coil with less inductance. I'm telling you guys, if you want free energy,   look for free SOURCES OF ENERGY, instead of wasting precious time on stupid notions like "breaking lenz's law"
Extracting energy out of a magnet is another story.  A magnet attracting to a magnetic material has just produced energy, but now what?   How can you demagnetize it and pull it away and then magnetize it again but not have to put the same energy into it, which you will have too inevitably (as the magnetic field increases the current in the coil flows against this opposing potential hence power flows into the magnetic field , or v*I)  Have fun with that one.
@winsonali
Did you succeed in setting up a closed loop system that works?   Is that what you said in a previous post?  I personally don't believe it.  It is obvious why from your other posts,  you have nothing and are just dangling worthless notions, just like I suspected long time ago.   If you had a WORKING closed system you would be jumping up and down with excitement, or perhaps I misjudged you, perhaps you have free energy machines running in every corner of your lab, so what's another free energy closed loop system?,  ahhh, who cares....
Better stick to the business of making SMPS, it's quite lucrative.
EM
Quote from: Nihilanth on December 20, 2009, 02:41:53 AM
It looks like Steorn has been a few steps ahead of Gotoluc:
http://www.youtube.com/watch?v=S5nae_I_Mus
winsonali
EMDevices:
i am fully agreed with your explanation regarding lens force
regardless of formula and description of lens force here is the reason of so called lens force
when a rotor moves in a static PM the first force encounters is the force of attraction between magnet and core material regardless of polarity .... this can be reduce by properly balancing the mechanical margins equally in 360 degree but cannot be fully finished .... they are just like invisible brakes.
when you move rotor mechanically to produce electric power the winding in the rotor starts getting voltage due to changing field now this makes the rotor a polarized electro magnet.....
each time the direction of the magnet aligned as the facing pole's inverted pole direction another greater force of attraction become active(this is lens force)  ....now you need move power( against lens force)  to keep it moving to achieve required voltage without load.
One new phenomena takes place when we connect load to generating rotor coils. the coils starts flowing current and become more heavily magnetized...we need more force to maintain the RPM to get proper voltage at consuming  current.....( i see this as increasing duty cycle in electronics)
the above description is mechanical force ... same are present in electrical as well
the KEY to understand
this is with my own experiments i called this effect "MDFGR" mutual dynamic field gate resistance if we control this effect we can simply convert the magnetic field in electric field.
what this effect is when magnetic lines passing through a current carrying conductor which is not magnetically permeable this effect force the material to to aligned atomic poles in the direction of external field flow as a result this changes the structure and gates of electronic arrangements and due to this reason the resistance of the material dynamically reduces and it starts consuming more and more current.
this phenomena is applicable to those materials which are good electrical conductor but poor magnetic conductor.
i have recently developed the formulation of an FE3o4 based alloy with some coating that wire will give you the same effect as core based coils but there will be no core required so we have reduced the greater mechanical force hindrance without lossing the efficiency
a lot of technical work is present with me and results of technical works are registered with backup videos.
the circular disk magnets facing each other can produce more power then conventional generators. there is a key don't get the power until and unless it is at the peak and stop taking the power instantly once you fill the power bucket. as i have done in genie.
Em devices :
i really want to share the new device with you which is self running now  just waiting for right time...
all the easy possible power generation methods are already in use with there efficiency what ever method will come up now will be out of the box and not in the existing lines.
for me a solid state generator is more preferable so i am concentrating on them rather then mechanical solution  but i have studied all mechanical power generation techniques very well.
winsonali
EM devices
@winsonali
EM
for your above quote i can just say one simple thing
"Time will reveal what i have"
posting on over unity doesn't mean that i don't have anything, you are also here... ;)
so yes i am jumping in my lab what ever i have achieved is remarkable.
i am not fishing for any investor i am self sufficient, the unit is now self running that makes it self selling as well if i just starts selling it to my family members and friends ( this is there right to enjoy this at first hand) and there friends i cannot full fil the orders, secondly these are the people so close to me  that i  cannot runaway from them at all.( this doesn't mean that i will not go commercial)
the success of the product is not IN "if you can replicate it"  the success is in customer/user satisfaction what it described it is doing
any way
i know one thing i have far more less knowledge then you have...
and i don't want to waste the time by giving explanations( other then technical)
i want to give and share my knowledge thats all, The members of the forum are my technical friends i am sharing with them.
by the way what do you think about steven marks device wasn't that working? if yes so we are here....
