New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
gotoluc
After posting the above I received the below Thought for the Day which is written by my Guru. Please note that my above written understandings and views are my own and are not necessarily my Guru's
Luc
Thought for the Day
January 5th
In this creation, wisdom is enveloped in ignorance. So long as the lamp is burning, there will be a shadow beneath it.That is just inevitable. So too, when the flame of illusion is burning, the shadow of ignorance persists, right underneath! However, the Knowledge of Self destroys the ignorance and makes wisdom shine, just as sunrise illumines the whole world and confers peace and well-being. To attain this result of peace, effort is super critical. The mind is conditioned to good or bad, by the environment. The reformers of today do not strive to transform the qualities of people. They are trying to bring about equality in economic matters, in outer life. Improving economic status alone will not bring about lasting peace. Lasting peace can only be obtained, when character is molded and developed. There is an urgent need to reform the character through the Knowledge of the Self. This reform alone will bear fruit, the fruit of peace and eternal bliss.
nightlife
 Hi Ali,
  You are supplying the unit with an undisclosed amount of wattage. We need to know exactly how many volts and amps are put in as well as exactly how many volts and amps are put out.
Watching the video it shows you turning down the voltage but yet the amp meter is pegging out. That tells us that you are not turning down the power, you are only coverting the power from 110volts to 30volts. Then you show 220 volts coming out of the unit and the amp meter showing a number that I can not read but is still considerably lower then the pegged out amount. This tells me that the wattage used is about the same if not more. I am sorry but no extra energy is being created. At least not with what you have shown us.
30volts X 100amps = 3000 watts in.
220volts x 10amps = 2200 watts out.
This tells me that you lost about 800 watts by using your unit. Please note the number used for amps are assumed based on the action of the amp meter. If you could give us a better view of the amp meter readings, I could give you a more accurate calculation.
I may be wrong because I am not the brightest and if am, please explain what I did wrong.
winsonali
nighttlife:
in all the videos i have shown input current
and in final video i have done some corrections and due  to this the power advantage reduced highly
the effect you are describing is in fact a good concept and this happened with me in beginning when i have improper switching it draw extra current but with properly designed system it takes far less current
in my new design i have isolated the input and out put through solid state means. We reduced the dimmer to lowest possible duty cycle and collect what ever we require during this period.
now the system is operating with DC so there are no doubts.
just wait for new video of self running system.
nightlife
 Thank you Ali.
I look foward to watching your new video.
winsonali
hello to every one
during the quest for the alternative energy i have just competed another product
i will be posting video of self running unit over the week end
here is a little bit details of my new product
