New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
neha9243
Eagerly waiting for your video,  keep the good work
many thanks and salute to your great work for whole mankind.
neha9243
winsonali
gotoluc
may be the reply address is ali@wintrac.co.uk
please send me emails at winsonali@yahoo.com
i am no more using wintrac domain
winsonali
neha
thanks sure everyone will enjoy this vidoe
and up coming device
forest
Quote from: winsonali on January 09, 2010, 04:40:55 PM
yes its a very simple thing i am using IRF 740 or 840 and the capacitors are 330 UF 400 volts
but the time for switching is based on residual charges if you connect 2 parallel path Mosfet you can ensure fast switching by cross over timing
the Mirco-controller you are using is also an important factor now i am using FPGA quite complex but very power full.
i will open source the genie circuit once my new device is on the screen all those people who have this thinking that high frequency can fool the meter they are wrong.
i am trying to up load my new device probably 2 moro you will be very happy to see the new Winson Charge Accelerator. this is the name of the new device.
Mosfets are very nasty elements they blow up very quickly, don't forget to put 10 k resistance to ground on gate pin it will keep it always low level and it will not go in floating stage and once you applied voltage to gate, put 1 K so you will get 1:10 ratio divider and the current will be limitise and protect the Mosfet to an extent
this is my experience when you directly connect mosfet and source jumps from high to low the tri state condition applies this is the period when most of the mosfet blow up coz a source to drain current is flow and the gate came in floating stage any thing can happen to blow so connecting a high resistance to ground will always deter the floating stage.
winsonali
Is that a circuit of two mosfets in opposite directions like in image I attached ?
Nihilanth
I hope you don't mind my asking a few questions out of curiosity Ali;
How much output have you managed to get out of your self-running device thus far?
What are the cost estimates of the completed device, components and manufacturing?
How large is the device?
If you could answer some of these, I'd greatly appreciate it.
"I think it's better to have ideas [than beliefs.] You can change an idea. Changing a belief is trickier. Life should malleable and progressive; working from idea to idea permits that. Beliefs anchor you to certain points and limit growth; new ideas can't generate. Life becomes stagnant." - Rufus the 13 Apostle.
