New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
hartiberlin
Maybe Ali is doing it this way ??
http://www.youtube.com/watch?v=PU5TtVq9LEc
;D ;D ;D
The power company will hate you for owning this device... ;D ;D ;D
How do they manage to spin the meter backwards ?
Is it just a cos Phi manipulation via capacitors ?
Kator01
Hi Stephan,
I do not know if it works if you do not place it directly beside the meter.
lets assumeyou have a linelength of 10 meter away from the power-meter you will have additional
inductivity involved.
On the website ( scroll down to the middle)  :
http://www.boondee.net/electric-power-saver/b4-88.html
they decribe the box has to be placed as close as possible to the breaker-switch-control-panel. Do they mean " the fuse-panel" ?
The subject is also discussed at ATS here :
http://www.abovetopsecret.com/forum/thread395990/pg1
Kator01
infringer
Is the bondee device legal seems to me like ignorance of a device seems to be on you...
I guess I need to know weather this device is legal...
I thought about purchasing one of these as well.
http://cgi.ebay.com/18KW-Power-Energy-Saver-Electricity-Save-up-35-money_W0QQitemZ250499538058
Cheap investment low risk...
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
FatBird
I bought one of those Power Savers on Ebay and took it apart.
It is just a 5uf 450 VAC Capacitor directly across the wall outlet that is for Power Factor Correction.
infringer
no kidding was it at all useful for your power meter I just bought one... errrrr oh well like I said not too big of a loss wish I would have waited a few minutes before jumping the gun but its just one less burger that I don't need anyways lol!
The power factor of an AC electric power system is defined as the ratio of the real power flowing to the load to the apparent power,[1][2] and is a number between 0 and 1 (frequently expressed as a percentage, e.g. 0.5 pf = 50% pf). Real power is the capacity of the circuit for performing work in a particular time. Apparent power is the product of the current and voltage of the circuit. Due to energy stored in the load and returned to the source, or due to a non-linear load that distorts the wave shape of the current drawn from the source, the apparent power can be greater than the real power.
In an electric power system, a load with low power factor draws more current than a load with a high power factor for the same amount of useful power transferred. The higher currents increase the energy lost in the distribution system, and require larger wires and other equipment. Because of the costs of larger equipment and wasted energy, electrical utilities will usually charge a higher cost to industrial or commercial customers where there is a low power factor.
Linear loads with low power factor (such as induction motors) can be corrected with a passive network of capacitors or inductors. Non-linear loads, such as rectifiers, distort the current drawn from the system. In such cases, active or passive power factor correction may be used to counteract the distortion and raise power factor. The devices for correction of power factor may be at a central substation, spread out over a distribution system, or built into power-consuming equipment.
-infringer-
