New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
robbie47
Stefan, I think he indeed switches capacitors by monitoring its voltage. Depending on the voltage levels the switching is performed. I think Ali uses a small microcontroler (PIC) or a FPGA to do the digital processing.
hartiberlin
Ali replied to me via email , that I am "pretty intelligent" with the idea of the Audio delay
line feedback loop and this tells me that it must be something like the principle of
an audio Echo CCD unit, that has a positive feedback loop and goes into oscillation.
This is also the only way I see a "Siphon" effect could work.
Ali now wants to design a unit that can be powered by pure DC input power
from a 12 Volts battery or a solar panel.
Regards, Stefan.
FatBird
Stefan, did you see my post on Page 5 of this Thread, regarding photos of the Spinning Aether?  If not, PLEASE do because of its IMPORTANCE!!!
Thank you.
robbie47
Quote from: FatBird on September 02, 2009, 09:06:45 AM
This is caused by over exposure of the camera sensor.
Some explanation can be found here:
http://www.dallmeier-electronic.com/it/prodotti/cameras/da-tenere-in-conto/ccd-vs-cmos.html
The bright light causes the sensor to saturate and causes the vertical bars in the movie.
Even when he hasn't yet connected his device and connects the board directly to the wallplug this effect is visible.
It has nothing to do with a secret energy source being visualized.
winsonali
ok guys let me tell you how this idea come to my mind
i am a scientist and have worked on various project in starting of this year(2009) one of my friend ask me to develop a UPS /inverter with extended backup power operating on 12volt battery  coz power cuts are too much now a days in his country
i give him an idea that just like if you are driving a car on a highway on staright  road you can save fuel by just neutral the car for some time and get it back on gear after some time due to inertia car will remain in movement for some time
like wise we can use the hysteresis curve (retentivity of magnetic force) in transformer  in the same way, we can call it magnetic inertia. I develop the circuit and its working the backup of the same 1KW UPS extended by 60 % now its operating for 6 hours before it use to last in 4 hours this is a good product for solar panels as well
the same friend ask me to develop voltage stabilizer in low cost that was only possible if i some how finish the use of transformer from the stabilizer
so i thought of siphon and designed the stabilizer which can increase the voltage without transformer so we can save the cost of transformer. copper is getting expensive day by day.
i developed the stabilizer successfully
while we conduct tests we realize that the input voltages are 30 at 1.5 yielding 220 with 0.7 amps
i was not at all designing any thing related to over unity or perpetual motion but the efforts for some thing else turned into what we have now
even if we do not think of any thing else this device can work as a transformer less A/C voltage stabilizer  by all means
Ali
