HAS OVERUNITY BEEN ACHIEVED ??? CHECK THIS LINK
Started by magnetman12003, August 26, 2009, 05:14:58 PM
mikestocks2006
This may aslo be of interest.
Both levitation and rotation of the spin plane.
http://www.youtube.com/watch?v=vAtQAIZo0Yw&feature=related
Nice thread/info
Thanks
Mike
jonifer
Magluvin
Just some thoughts on this over the years..
What would we have by winding 2 size wires in bifi? Recent thoughts are these...
The smaller wire is very small. If wound together and very neatly, the larger wire could basically lay as if it were the only wire and its inductance and resistance would pretty much be the same as if it were wound alone. So the capacitance would be asymmetrical.
Looking at the first circuit given on this threads 1st page is hard to discern the connections to the coil. The second circuit given shown below again is more detailed as to how the coil is connected.
If this second circuit is correct, then there is a diode in series where the coils are connected in the middle.  So if the coil gets a mag pass depending on the polarity and direction, the coil as a whole can gen up some charge into the 10uf cap. So after the charge period, each winding of the coil is at the voltage level of the cap that can be measured across the diode.  So then the reed closes at some point, and as shown, the reed would short out the cap along with the charge on the coil, which would flow through the diode now that the switch end is closed. So there may be a mag pulse from that and probably optimum reed close position would be if the poles of the ball mag are perpendicular to the coil, pull one side and push the other. Just a bip to possibly keep it going. it could be that the cap is just there to hold the voltage up until reed closure as the charge in the coils may dissipate before the reed gets to close. Dunno yet. Both circuits short the cap when the reed closes.
Now if the circuit were beyond what was given, I might think it could go like this....  Ill draw the circuit later
So we have the large wire and the small wire bifi and the large wire should be identical to a single wire coil of the same size, except this one has a fine wire that can lay in the open spaces between the large wire turns.
Also here we have the diode in the series connection of the coils, and they charge the cap in series, but, the discharge with the closing of the reed switch only discharges into the larger wire coil to push/pull the mag.  That idea comes from the question, why the 2 size wires? Why make them 2 sizes and just have them in series unless there is an advantage due to the asymmetrical capacitance.  So it seems more likely that the coils can work together to charge and possibly just discharge into the larger coil, lower ohms, harder pulse, etc.
Always wondered about the 2 wire sizes and I think that was what most interested me in being way different than others.
Mags
Low-Q
My biggest question is: How is it possible to calculate a circuit, accurate positions etc with math that says the output or product is higher than any given input?
My calculator still says that 1+1=2, 1-1=0, 2x2=4, 2/2=1.
Vidar
                          over-unity " output>input process "phaenomen:
It is not a practizising problem,it is a mathematical and physics formula problem and phaenomen exploiting barrier :
                                   (-)1  / 0 =
          Divident positv/negativ and Divisor neutral=zero
                      total result = SYNTAX ERROR
          the need 4D/>4D....Minkowski Space-Time-Koordination
https://www.google.pt/search?q=verschiebungsstrom&ie=utf-8&oe=utf-8&client=firefox-b&gfe_rd=cr&dcr=0&ei=efGwWcn6BIWt8weWka_ABw
physics description : Biot-Savart/Ampére/Laplace law applying
listen to the Dr.Pavel Imris capacitive coil patents/publications
the unknown and unkalkulability for engineers and technicians :
measured and approved=granted by prototyp,INPI Lisbon 2008/2009
https://worldwide.espacenet.com/publicationDetails/description?CC=WO&NR=2009154492A3&KC=A3&FT=D&ND=4&date=20110331&DB=EPODOC&locale=en_EP#
                                 force  by power
                             5 KW     : (220V X 68mA )=
                          R=resistive,is it not ?  ::) ;) :)
I am "New Waver",it began with "the class of 1984",visiting the
             http://www.prmg.de/index.php?id=33
first minutes by the new class constitution and entering from the first teacher for the first hour lesson,french language:
Fr.Pommer,+/- 25 years old ,greased hair,hippie-like weared
             I see    I think    I decide  open minded and loud :
                          "Mein Gott,ist die haesslich !"
         https://www.youtube.com/watch?v=yOE9L6DNQds
By the end of the school-year our class teacher Dr. Michael Hauser
remarked that our class has been the "Schlimmste" of all classes from the total KFW.
= Zivilcourage : 1+ or Note: 20 cum laudae  ::) :) :) :)
                      Teachers,respect your Audience !
                       Audience,respect your Teacher !
                                  using the 3.dimension sins
                                         " tit for tat "
                                      Bio(s)analytics
https://www.youtube.com/watch?v=i2wmKcBm4Ik
https://www.youtube.com/watch?v=Q3Kvu6Kgp88
