Bedini SSG - self sustaining
Started by plengo, August 28, 2009, 08:04:34 PM
plengo
Sandy,
after reading your "The Secret Life of Capacitors PDF" article I immediately remembered some of my own observations concerning the voltage fluctuations on my experiments.
Some of the fluctuations would be more pronounced on certain days and hours which many times rushed me to come to the forum and post a "success" message while not to only wait another day and the voltage would drop again (causing me great deal of frustration).
If I did not understand your article wrong, would be possible to utilize that moment where the earth is charged higher?
I quote your choosen best explanation:
Quote) our capacitors are being charged directly by the ionospheric charge above us;
(i understand that a Faraday cage only blocks AC fields, not static DC fields)
Don't you think would be possible to have an array of capacitor or batteries that utilize that extra energy (during those peaks)?
Fausto.
NerzhDishual
Hi SSGers!
BTW:
Salutations to Nul-Points (the guy from Dorset/GB). :))
Thanks to Plengo for his creative SelfRunner-SSG-v2 CirCuiT
Worth to be tried indeed.
My (poor?) understanding:
At a first glance, 'statically-wise',  the voltage across C1 should be 12 volts!
If it is not the case that means that the C1 cap and the bat are both feeding the CCT while being both charged.
But the bat is kinda 'helped' by the cap.
BTW2: IMHO, the cap and the bat are not charged with current but with voltages spikes.
Something to try, IMHO: to put smaller C1 capacitor and change R4.
Do you remember this DJT CCT where a tiny 100 pF cap is used to power the second JT?
This is Tesla stuff...
As far as I can catch it, a self oscillating SSG is an SSG with a non spinning but
vibrating rotor.
In that case, IMHO, it looks like a mere basic Joule Thief with, notably, an extra diode at
the transistor base and a magnet 'near' the double coil.
Is it not?
I have observed some self charging effects (bat voltage increase) with one JT-like CCT (triple coil).
Unfortunately, it does not last more than a "small couple of" hours and after that, the bat voltage
begins to decrease like my patience.  :-\
Actually I did not use a very tricky wiring and the Plengo CCT gives me some ideas
for my JTs and my SSGs.
Very Best
Nolite mittere margaritas ante porcos.
mscoffman
@plengo
In the "Self running coil" link;
http://www.overunity.com/index.php?topic=8892.0
User gotoluc used a stator coil from a small utility AC powered vent-fan motor
as a "probe coil" to capture some energy back from his main coil. When used for
calculations the behavior of his main circuit, which was powered from a capacitor,
added to the extra energy captured by the probe secondary coil seemed "way"
overunity.
Unfortunately he didn't go the route of using a pulse transformer and/or a
diode voltage multiplier to step the voltage from the extra coil energy up in a
way that could have inserted it back into the capacitor, to demonstrate overunity.
I was thinking you could try something similar. If you do try it, you should load the
coil with a resistor rather than having an open coil, but the concept is to try to
get some power back without affecting the main coil loading initially. This might
nudge your self recharging battery circuit to overunity and allow you to optimize
on the other side of unity power gain. You also have some microcontroller
capability to try, which could get interesting.
I also wonder if possible to "punch through" the fantom charge voltage
by stopping charging and putting a high load on the battery for a very brief
time to correctly assess the actual battery voltage-state-of-charge.
:S:MarkSCoffman
plengo
theviper0308
hye... im newbie here. sorry if i ask a noob question..
i have read about the bedini generator.
it using two battery right. one is use for drive, another one is for charge.
if the bedini is running, is is the drive battery will drain? is it i need to change the drive battery in another time?
sorry for my bad english. i hope you understand what i mean. thanks :)
