Bedini SSG - self sustaining
Started by plengo, August 28, 2009, 08:04:34 PM
mscoffman
Quote from: plengo on October 25, 2009, 07:27:54 PM
Today I finally finished my new 14 switches board. Tested and read to go.
Fausto.
ps: almost ready. Still missing 2 connectors.
That is a good looking board. I am impressed with your handywork.
Let us know what experiments are getting done with it.
Once you find some overunity energy - I'm very sure more will follow.
:S:MarkSCoffman
Magluvin
Hi all
I did a lil experiment this morning that may be of interest.
I have a simple pulse motor setup using 2 AA nimh, a coil, and a reed.
I used a diode and a wire off each side of the drive coil to charge a separate cap, which charged to 25v. Then I used another coil, not near the rotor, a reed, diode and another cap, and the reed is pulsed from the rotor, taking from the first cap, 25v, as a source, and the second cap is at 222v. I havnt tried a 3rd stage yet, but is it possible to keep adding stages?  has anyone tried this?
I tried a 3rd AA added to the other 2 and it went above 300v, my caps are 275v, so I just did it briefly.
Mags
plengo
@Magluvin
thanks for sharing your experiment. It is indeed interesting. Could you provide a schematic and a picture of your setup, please?
Fausto.
Magluvin
Thanks. Yes I will. Im running up to my shop to get some other caps to try and I will do a YT vid. The 2nd stage seems to have higher current also compared to just a first stage bemf, maybe its just a bigger blast. Also I would think that the first stage bemf would have been higher than 25v but so beit. The rotor makes a great timing/switching for the application.
Be back in a lil bit
Magluvin
Magluvin
Ok Im back with the gidgits. Im just going to clean up the setup so it is easy to understand what is what for the vid and my cam bat is on charge.
Will let you know in a few when im uploading.
Magluvin
