IST'S FURNACE FAN PULSE MOTOR SELF RUNNING NO INPUT BATTERY
Started by innovation_station, September 04, 2009, 08:53:09 AM
innovation_station
now i have showen the BIG ROTORS IM BUILDING ...
next im going to show
for the smaller rotors  the motor caseing i have built from an old wire spool
this unit is for my furnace fan motor i hope to finish the motor caseing today ...
i have almost all the required parts gathered up and ready to assemble ..
im happy with the way it turned out it is simple and looks darn kool and easy to adjust and assemble ..
ill add some picture of all the parts i used to make the caseing..
it is a 30" there bouts wire spool  it had 3 bolts holding it togather it had wood slats in the center ..
i then used a card board tube from the big spools i had to redrill the connecting bolts ..
not much to it ....
ist!
here is a picture of a wire spool i will use for a motor caseing ..
and here is the cardboard tube .. i will use for the caseing ...
this spool showen is not the exact same as i have already used ... this one has 4 bolts...
SkyWatcher123
Hi folks, Hi IST, you know I remember reading an article which may have been on Bedinis site or somewhere where a guy used a large heavy, round, wooden kitchen table top for a flywheel and it was powered by a 12 or 24 volt dc motor and 1 or 2 permanent magnet generators recharging a couple lead acids and all were connected by a belt and it was said this may have been self running. So maybe it is true after all that one can tap enough energy from a large enough flywheel to become self sustaining. Also another story of a test that showed a flywheel that required say as an example 100 watts to rotate up to a certain speed, then after a given length of rotation time is stopped and then started up again, it now only requires say 10 watts to rotate to same certain speed, although if you wait too long to rotate it up again the lower input effect is gone. This seems to suggest an effect like spinning water in a glass and it keeps spinning for a time, only in this case it must be the aether spinning or whatever we want to call what the flywheel is affecting in the space it sits. I think your motor has good possibilities.
peace love light
Tyson :)
innovation_station
i have been working away on both thease units ...
ill add some more pictures today..
ist
innovation_station
well i picked up a few more truck loads of spools ...  ;D
so ill get it built sooner than later
also i removed the rotor from the 30 hp induction motor what a job ... i had to grind it off it took me 3 days ... but i got it off
i have since picked up about 30 more spools .. some are quite large ... over 5 feet ..
here is a picture ..
ist!
MrMag
