Bedini pulse charger buster
Started by Silvije, September 04, 2009, 11:43:33 AM
Which buster schematic just might work (produce "free energy") in your opinion?
1 - 2 bifilar coils
2 - 1 trifilar coil
3 - 2 bifilar coils
4 - none of them
Silvije
thank you for your reply and files..
to be honest I have experimented with pc fan circuit something similar to Imhotep's version of Bedini circuit if I am correct, that is why my idea also differs from ssg motor...
but as you all guess I had no real success with that circuit so I put that aside and took pencil and paper just to write down some ideas..
that is the reason I do not have any plans for size of the rotor or magnet orientation at this time...
Maybe those of you with more experience with Bedini circuits or Mr. Bedini himself if he is reading this, could suggest some good setup...
I started with pc fan because I have a few fans and it is very simple to modify them... I do not have any other motor setup and I guess it would not be that easy for me to make one because I am limited on resources and time at the moment... also I do not have any lab for experiments as some of you might have... :)
so, if anyone finds some of this ideas good and is willing to give it a try, you are more than welcome...
and if some of you make one of this circuits please publish the results here
s.
Groundloop
Silvije,
I maybe try out your setup later on when I get more free time.
Thank you for taking time to answer my questions.
Groundloop.
guruji
Silvije what are R1 and R2? Can you please tell me those resistances?
Groundloop that circuit works as well as Silvije? cause it's modified a bit.
Thanks guys
Silvije
I guess those resistances depend on coil and transistor characteristics.
Try with values about 1k.
But I will point out this again: you should look at this schematics as an ideas for circuit, you should not look exact parts and their values... that needs to be determined, I guess according to values of Bedini setups which are "known to work"
regards
the_big_m_in_ok
Quote from: Silvije on September 04, 2009, 11:43:33 AM
This is in fact "double" Bedini pulse charger which uses 2 batteries which charge each other simultaneously. I called it "buster" because if the Bedini circuit does not do anything unconvential, the batteries will eventualy be both depleted... however if the charging captures some of the "energy of universe" this circuit have a good chance to be perpetuum mobile :) which I doubt.
There is no need to swap batteries or anything, first battery is charging second and vice versa...
you are welcome to comment and to build this circuit of course and tell us all what's up
I voted yes on the survey, but I couldn't say, "With reservations."  You'll still need a rotating wheel and several North-pole-side-out magnets glued to it, for this to begin working.
Using something like a relay to trigger the transistors would make more sense to me.
Counter-winding the coils for a Caduceus coil /Joule Thief effect might also be useful.
Adding an additional coil to the trigger coil and then harvesting the EMF created was also done by others.
--Lee
