exploiting equilibrium
Started by mr_bojangles, September 10, 2009, 11:49:50 PM
FreeEnergy
i'd really like to see an animation of this
FreeEnergy
this seems more like an advancement of Yu oscillating Generator ( http://www.overunity.com/index.php?topic=8051.0 ).
you're using purely mechanical means for your pendulum system adding leverage, an extra pendulum, and a rolling wheel that oscillates horizontally between the leverages. also no magnets here! pretty neat.
this idea isn't very hard to build in real life.
the way i see this system self start is when it reaches a certain speed, after that it will self run.
this is a great idea!
thanks for sharing.
P.S. let me know if i misunderstood your idea.
mr_bojangles
well the intention of the magnetic rolling wheel is to induce electricity into stators, which would be the energy used to further power the machine
the thing about magnets is that their strength and mass are not closely related necessarily
we could use extremely small (mass) magnets that are high in power to generate the electricity
even if we didn't attempt to use a pendulum type oscillation, could we not just equal the weight of the counterweight to that of the incline + disc + any torque resulting
this would balance the system and then we would be able to manipulate the incline with only the resistance of the friction of the fulcrum
what i am suggesting is to use a large amount of dense mass, weights, that will produce the exact same torque as the disc on the incline, while being twice as close, this is possible, and the system would balance out
my drawings are huge over exaggerations of what would be necessary for this machine to work, moving the bottom of the fulcrum only a couple degrees would put the incline at a sufficient angle for the disc to roll,
this is essentially a wheel on a ramp, theoretically it should be able to work at only a few degrees steep
the angle is important in the aspect it will be giving the disc angular momentum to combat the lorentz force induced by the stators
it does not need to move hardly at all to manipulate the angle of the incline, which is the only reason this could work
the beauty of the fully balanced system means that mass is basically irrelevent
this means we can have infinite length of incline, as well as infinite inclines and infinite discs to roll on them
@freeEnergy if it makes sense to you i doubt you misunderstood
@com i appreciate your input and thought provoking discussion
even if it doesnt work i hope someone can think of how to improve it or use it in another aspect
"If at first you don't succeed, try, try again. Then quit. There's no point in being a damn fool about it."
-WC Fields
FreeEnergy
anyone willing to build this in working model 2d? would be nice.
onthecuttingedge2005
Gravity and magnetism 'only transfer energy'. they have no direct working energy unless there is extra energy present working together to transfer it.
it is the simple truth.
