Yu oscillating Generator ---- Overunity YOG Model
Started by WattBuilder, September 14, 2009, 03:19:15 AM
0c
Quote from: norman6538 on November 12, 2009, 02:49:30 PM
This is similar to my work here where the pendulum swings higher than
its dropped point.
http://student.ccbcmd.edu/~norman/magwork.html
So if we switched the stationary magnet polarity on each swing it might continue on its own.
Norman, interesting stuff. How long have you been doing these experiments?
Have you seen the "Magnetically Assisted Pendulum"?
http://www.youtube.com/watch?v=SP_o1_jBUSM
0c
norman6538
@Norman
good work. That is a good way of looking at it in that rather rotating the swinging magnet reversing the polarity of the fixed. Great idea and good lateral thinking. Would be interesting to see (even if you manually rotate it at this stage) if it got an accumilated gain on each swing
Kind Regards
mark
I did that last night by making a Model T crank handle for the stationary magnet but was not able to get it to keep going... I suspect 1/8 inch is not enough extra . Notice that in my pendulum experiments I layed the pendulum down deliberately to reduce the gravity force and put it in range of the magnets. I do not like to work with strong magnets because they hide things that would otherwise been seen.
reference to my work http://student.ccbcmd.edu/~norman/magwork.html
Norman
winsonali
hello Guys,
i am submitting a simple diagram for continuous movement of pendulum instead of using servo motor and this will use electric power just for very short pulses may be this will help a little bit
i have developed a new method of producing electric power without inter crossing the magnetic fields may be some one can give me better suggestions what ever you are doing mechanically i am doing electronically
I was basically designing input section of genie without a dimmer with AVR capability then i think about using permanent magnet in a transformer that experiments failed and i saw number of patents dating 1954, to 1978 and i also review Tom Beardom's MEG i realize something is not right in this method and i developed this new technique of using magnetic field with out inter crossing and produce good  use able electric power. These are really new lines of working with magnetic fields this involves highly precise sensing circuits and software
Few results of my experiments raised these questions
1) what is the speed of magnetic lines
1A) what is the frequency of magnetic lines.
1B)  what is the resonant frequency of any magnetic material.
1B) an aluminum wire coated with silver offer good conductivity(current travel on surface area), but eddy current is highly reduced
2) why a stationary magnet do not produce eddy current or electro magnetic current in a coil which law define this part?
3)  an air core coil when in operation produce and offer electronic characteristic showing blocking AC current, exhibiting current lagging , LC circuit acts like pendulum , but it don't attract metal as a magnet until and unless it has some permeable material experiencing its current flow
in my experiments i am developing methods for  reducing the eddy current loses, inter crossing of magnetic forces even then you can generate good amount of electric current
these are really new lines of working with magnetic field This involves highly precise sensing circuits and software
please note i am not using pendulum to generate electric current
details of my work is here http://www.overunity.com/index.php?topic=7987.340
norman6538
0c
Yes - and that is what tweaked me to do my simple experiment.
I just love simple experiments that have not meters and measurements
to be disputed and argued about.
I have a magnet addiction for about 5 years now. It took me probably
6 months to tweak up the pendulum to where it was in the video.
But can't take it to the bank and get money. However it defies our
current science along with the Finsrud device. And I just love that.
Most in the boxers deny what it does.
Norman
FreeEnergy
this is cool!
all you have to do is flip the magnet's polarity at each swing so the pendulum swings higher and higher!
http://www.youtube.com/watch?v=D3Z0t6kNMVw
