Yu oscillating Generator ---- Overunity YOG Model
Started by WattBuilder, September 14, 2009, 03:19:15 AM
WattBuilder
Hi Exnihiloest,
Work is okay…. As long as it produces more energy out then in.
Remember that the YOG has a lever as part of its design. It is lifting a counter weight in it’s lower pendulum. Then weight will swing back down.
You would get a mechanical gain depending on your lever’s ratio.
The force of the lower half is greater then the force of the actuator.
The magnetic ramp/track will drive the lever top thru back and fourth. Making up for any pendulum loss.
I hope that was explain clearly.
onthecuttingedge2005
I think Bessler's Wheel is an over rated clock mechanism. nobody can get it to work but my clock works just fine. lol
sorry. I had to.
Jerry ;)
WattBuilder
Hi Jim,
I haven’t thought much on the drinking bird, but it’s interesting on how it works with temperature.
I try to keep an open mind on different actuators until tested. But I would like to point out some of the advantages of the magnetic ramp used on the YOG.
1.   The ramp can control the amount of driving force on the lever by using stronger magnets. (example: 5lbs of force)
2.   The ramp length will control the distance of the lever travel. (example: swing from a 10 o’clock to a 2 o’clock position )
3.   The ramp magnets does most of the work without electricity. (example: it will maintain 5lbs of force swing from a 10 o’clock to a 2 o’clock position )
On the video that you posted you can see that I replaced the turbine with another method. During my earlier testing I wasn’t able to get my hands on a low drag turbine. The common ones just had too much resistance turning due the iron core design. So what I did was use the basics of an ironless core Axial Flux Permanent Magnet Generator. If you look at the lower half of the YOG, you will see a half circle. I used the circumference as a dual rotor. The wooden frame was used as a stator holding the coils between the rotors. By doing this I greatly reduce the resistance and drag for the pendulum to swing. Also using Litz wire helped even more by getting rid of the eddy currents.
The point I’m getting at with the turbine is that any overunity device will have to leave room in their design for the load.
exnihiloest
Quote from: WattBuilder on September 15, 2009, 05:26:20 AM
Hi Exnihiloest,
It explains nothing about the work. Force is not work. Work is force times displacement, it is conserved by a lever.
No calculus, no experiment: it is a profession of faith.
WattBuilder
exnihiloest
Sounds like you made up your mind.
Also reading some of your post. It looks like your going around bashing other people’s hard work.
So I’ll play along with you……. What part of my device troubles you?
Oh and by the way save the smoke screen talk.
I never said force is work.
Are you sure you have an understanding of how my device works?
