"Cold current" may be caused by novel magnetic subatomic interaction
Started by kmarinas86, September 16, 2009, 03:30:38 PM
forest
It's very interesting and quite possible I think, but to let others understand you need to describe it in steps , each one on separate picture.
Later you can explain resonance in quite similar way because it is proven that odd harmonics take energy from stationary magnetic field, in our case from Earth magnetosphere.
tagor
Quote from: forest on September 24, 2009, 05:42:16 AM
yes
could you explain with more detail
kmarinas86
Picture and Microsoft Word File Attached.
Copper Potential Energy Quantum.doc
kmarinas86
Quote from: forest on September 24, 2009, 05:42:16 AMLater you can explain resonance in quite similar way because it is proven that odd harmonics take energy from stationary magnetic field, in our case from Earth magnetosphere.
I think the reason why odd harmonics are special in these alleged OU devices is not because they are harmonicsî ºit is because when they are put together they form electrical signals that produce more reactive power. Superimposing sine waves in this case are only a means to that end, that is, to generate waves where voltage can lead the current, and vise-versa. In the system I described, which claims that there is alignment of subatomic magnetic moments, voltage must be set up to lead the current to an extraordinary degree. This can be done by using a spark gap or some other method such as the implementation of odd harmonics.
I believe that the Steven Mark TPU device causes electrons in the collector coils to heat up accelerating them into two opposite directions, according to the orientation of each electron's magnetic dipole moment with respect to the magnetic field polarity of the control coils. This creates a pressure disturbance that is more along the length of the collector coil than in any other direction. However, because of the firing of control coil segments in quadrature fashion, some of these electrons will be pulled in the direction of the firing sequence, while the electrons being pushed the opposite direction will be accelerated for a brief period and will thus have a lower duty cycle. This will in fact create a net directional movement of electrons.
According to my hypotheses, the air at some further distance from the TPU will be colder, but closer to the TPU device it will be noticeably hot. Thus, the phenomenon of cold current/cold electricity/radiant energy used by the device is obscured as a result of the formation of "a queue of heat convection". This "queue of heat convection" is the plague of these devices, which even Steven Mark couldn't solve. The "queue of heat convection" is the heat emitted by the TPU device which was previously absorbed by the control coils of the device through the process of cold current/cold electricity/radiant energy, which is then remitted by the heat losses in the collector coils and can be redelivered to the control coils via air convection currents. However, removing the air convection currents does not save the Steven Mark TPU from meltdown because the electrons going in opposite direction to the firing sequence may still contribute to the heat inside the coil, power which does nothing to help increase total power output. Given the way the Steven Mark TPU is built, heat generated in the collector coils can conduct back into the control coils, disrupting the control coil firings' ability to maintain the phenomenon of cold current/cold electricity/radiant energy, which must be remedied by a control circuit. However, the heat remains built up, and it is eventually too much to bear for the control coils. The TPU device will never get off the ground as long as these "queues of heat convection" build up too much under load. Thermal insulation between the control coils and collectors coils will be needed to some extent to prevent this from occurring. Refrigeration is also an option to consider, but that is probably more expensive and inefficient.
I do not believe the performance of the Steven Mark device is dependent directly on the magnetic field of the earth. There may be correlations between the magnetic field of the earth and the temperature in the laboratory, since they are both affected by what is going on in the sun.
sparks
  Water is a great converter of infrared energy into thermal energy.  Cold current is cold because it feels cold.  The human being radiates energy in the infrared spectrum.  This conversion of potential energy stored in the water of our bodies is sensed by the brain and we feel cold.  Around high potential electric fields cold current insues.  A condition exists whereby there is increased radiation of infrared photons towards the high potential electric field.  This is not free energy it is conversion of thermal energy into electrical energy.  I believe that a high potential field causes ionization of any neutral atoms present in the field.  The energy required to ionize the neutral atoms needs to be input.  A high potential pulse acts as a catalyst in the endothermic reaction.  Once ionized the plasma formed displays a negatively charged face.  By this I mean free electrons sheath the positive ions.  The space where there was once randomized molecular vibrations and boatloads of thermal photons emitted and reabsorbed by the electrons of the matter contained within that space is now ordered.  There is little or no radiation of any type from this cold space.  Thermal photons caught in the matter now convert to plasma currents or kinetic energy of the electron sheath of the plasma.  A stable plasma configuration can exist and we cant see it because there is no radiation from it.  I think some people call them a black hole.  Light doesnt escape because it is converted into the mhd currents within the  plasma mattter.  The electrons absorb photons but are accelerated.  There is no synchrotron or thermal radiation because there is no deacceleration of the currents.  Just acceleration.  Enough acceleration and density and the plasma can begin to pinch the positively charged cores so that they fuse.  The conversion of mass to energy results in excess thermal energy in the core of the plasma.  This is absorbed by the sheaths to some extent but begins to create chaos in the sheath currents.   Currents begin to deaccelerate collisions transfer of momentum and the plasma begins to glow.  The big ones even explode now and again and a whole new galaxy perhaps an inflating universe is formed.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
