Free energy gravity motor Pinwheel Generator
Started by Russell Lee, September 17, 2009, 01:56:59 PM
Russell Lee
  I would like to bring to your attention the free energy gravity motor called the Pinwheel Generator that was given to the whole world by the Designs for the World  Project:  www.Squidoo.com/Pinwheel Generator.
  There is another gravity motor given out but the only design published represents the first raw design which has been improved to the definitive design.  The raw design can be located at:  Archive.org/Godproven.com/Apr06/pages 59-64.
  The improvements are as follows:  1)  The water does not exceed the top of the inner tank.  2)  Cables run from the top of the wall of the inner tank, through a pulley attached at the base of the upper tank, and out the main cylinder to connected weights that assist bringing up the inner tank to refill.  3)  There is a rubber liner (a large inner tube will work) attached to the bottom og the inner tank to the inside base of the main cylinder.
  Both Generator designs have been given to all.
                                  Regards,
                                         Russell Lee
onthecuttingedge2005
Hi Russell.
could you post a direct link because those links don't seem to be working for me on my end.
Thanks.
Jerry :)
FatBird
grayone
Russell; Your links don't show nothing. But there are many wheels given open sourced but it still doesn't mean any of them work and most likely nether the ones you mentioned.
sveinr
Here is the right link!!!!
www.squidoo.com/pinwheelgenerator
