Prof. Tutor shows Zero Point energy extraction into mechanical rotation
Started by hartiberlin, September 22, 2009, 06:58:10 PM
Xaero_Vincent
Yeah... at atmospheric pressure the machine operates much like an electrostatic motor with ion assist. In air the energy from ion wind and electrostatic discharge is overwhelmingly greater than the pressure from vacuum energy oscillations.
Solid dielectrics wont do any good because they increase capacitance and weaken the electrostatic field. Vacuum is the ideal isolator for this machine but its worth experimenting other forms of dielectrics, such as compressed gasses or maybe oil--just in case.
Small scale experiments with COP > 1 can probably be conducted for under $5,000. You can probably pick up a high-powered rotary vacuum pump with an ultimate pressure capacity of 1 * 10 ^ -2/3 Torr for a few grand and buy a small pexiglass vacuum chamber for $500-1000. You might be able to build a machine of a few watts with such an investment. Of course this doesn't include the cost of buying or building the generator that will covert rotation to electrical power.
I told Dr. Turtur that my long term goals will be to build such a machine and replicate his results. However, I have to invest my money in more important things right now. I can't yet blow $10K to build a machine that can power a few light bulbs.
alan
This only proves Stanley Meyer was right!
Just lock and hold tight the electrons and let voltage be on the output, then switch on off this electrostatic field corresponding to the waters mechanical resonant freq.
sm0ky2
i would like to run some tests using a wimshurst machine.
i can easily develop a 30Kv potential with very little input energy.
does we know how the "fins" are arranged on the spinning cup to produce rotational motion?
seems like its just made from an aluminum can. replication is probably not very difficult.
triffid
I have heard of mineral oil being used for homemade capacitors.Triffid
