4th Dimensional energy?
Started by Clarky, March 07, 2006, 08:54:32 PM
FreeEnergy
I can be off track but, all I see is One Universal Dimension.
pjrsullivan
Between the 4th and 5th dimension is where the 'Plane of the dimension' is located.
Our 3 ordinary dimensions are Length, Width and Height.  The 4th and 5th dimensions are the motion of the planet and outer space.
According to Kaluza-Klein theorem (1938) between the 4th and 5th is where torque is produced from the high speed motion of the planet (18.5 miles per second).
There is no friction point between the 4th and 5th dimension so the question is "How do we develop torque to drive our machines that are hurtling along through space?"
What is happening in many over unity devices is an acceleration in the light mass particles causes a time rate variation (Relativistic time space contraction) while the heavy mass particles remain non accelerated in the heater or motor coil of our machine and remain at their original clock rate.
The acceleration generated by our machine  produces a contraction in time, causing the light particles to become displaced within the time space continuum; they depart the original inertial frame of reference (the first 4 dimensional aspects of the frame) and temporarily access the "5th" dimension. When they return to the 4th dimension they can not land in their original (Shell) position  in the electric field because their time clock rate has changed. The heavy particles that remain ‘time’ unchanged now attempt to become destabilized while intertwined in the motor or heater field coils of our machine causing the 'Static fields' of the planet to pour energy in to maintain their position in the original inertial frame of reference (4th dimension).
The light mass ‘time contracted particles ‘ are now resident in the 5th dimension and when the field strength increases to offset the torque produced by the destabilization effects of this over unity machine created extra dimensional reaction, (Static fields, which are also the planet’s inertial fields and zero point fields) the energy increases to overcome the destabilization in the time space continuum and the light mass particles  will be drawn back to the 4th dimension, the original frame of reference.
A 'Lorentz pinch' contains our energy taken from the Cosmological process.
From the time of Faraday it has been accepted that only a kinetic field was useful for the production of electricity, but the Static field of the planet is the most powerful field of them all.  It is comprised of the mass of the universe. This also helps to explain the curious nature of Cold electricity; it is arriving from the Static planetary inertial field.
PS: Tom Bearden got it right a long time ago. He referred to ‘time reversal’ concerning particles. He also suggested to look at the Static field as one that had available power. From rereading his work, he said these things about 15 or more years ago.
Dr. Eugene Mallove likely had this figured out back in 2004, but didn’t have the opportunity to explain it to us before he was stolen away.
You tube has a video that covers this area:   â€˜Static field technology’
Or you can read:   Cold Electricity..What it?
lulu.com/content/e-book/cold-electrcitywhat-it/7385481
EELRIJUE
Quote from: Clarky on March 07, 2006, 08:54:32 PM
First of all, hey!  :) im new here.
A bit about me Im 21 year's old and an ex design student from Wolverhampton University in England.
I work with animation and conceptual design.
I am totally intrigued by overunity subject matter, overunity obviously meaning your getting more useable work out than your putting into a system, at first I was obviously skeptical  :P.
Ive read alot books, articles, websites, and what makes the most sense to me are Thomas Bearden's talks about 4th dimensional energy and how the atom is already in perpetual motion making our visible universe one giant negative entropy operation in its very essence. Also how present science is trying to explain phenomena such as the Casimir effect, and Aharanov Bohm effect in terms of 3 dimension's clearly failing so they are forced to use a 4th dimension to explain the energy change using it as postulative rather than a reality.
For instance, in quantum physic's they require that there exist virtual particles, which are needed to explain the existance of the observed process. Yet these are considered postulative and not real.. yet without these imaginary pieces it would not function.
So it makes more sense to me anyway, that these perpetual virtual elements are real and are just directly undetectable at present. I find these theories make alot of sense in terms of explaining the link between gravity and electromagnetisim, dark energy, the cosmological constant, and the source charge problem.
I dont mean to patronise  :) Im sure people already know alot of this stuff.
So I honestly think under the context of future theories what some people call perpetual motion will oneday be recognised as a new power source, and that overunity is perfectly acceptable, the only difficulty is right now we dont consider the 4th dimension to be energetic, and that is all that hinder's that understanding.
I believe that alot of our present preconception's of energy under present theory are misguided and a majority of modern science is still thinking too 3 dimensional about the universe, but if you read about higgs boson's and the higg's field I believe all of that is about to change.
4th dimension is only TIME.
Trying to draw energy from the time dimension is pointless. But we will have to use the time dimension in order to get to the 5th dimension, right?
Yes! Because time is relevant to an oscillation which is a vibration. So we use the interval of time as a frequency and we go very high in order to grasp at the yet even higher, 5th dimension.
We want 5th dimensional acquistion.
magnetism in repulsion in high vibration will do the trick... using natural geometry as well. Run away conditions for vibration to seek the highest vibrational limit. You get resonance and then you get in pouring energy....
Higg's field??? try Zero Point energy field or the vacuum field. Or dirac sea. Quantum vacuum fluctuations. High energy in high frequency.
perpetual motion is everywhere in this universe. All atoms, all structures in the universe work off of the principle of perpetual motion and always have.
It's mankind's error to think it isn't about perpetual motion. Mankind has closed themselves off from over unity ideas, because most of them don't believe in perpetual motion...which is just as real as the noses on their faces.
We can therefore create true perpetual motion machines...and there is no law to violate...because the Zero Point energy field makes it possible through the 5th dimensional acquisition. Energy is not created, it is tapped from the 5th dimension and also used to keep the machines running in overunity.
There is enough raw power in the ZPE field to destroy world's, but it must be used in accordance to Laws of nature. Vibrational law being the highest extremely important law. Magnetism to follow. etc.etc.
If the Law is broken and not followed, cataclysm will result. Depending on the size and scope of the machine or machines which will try to gain access to the zpe field realm.
Only resonating vibration can tap the zpe realm WITHOUT consequence.
Any other way, will result in disaster.
Keep that in mind, and ask yourself if anyone is attempting this type of high science experiment?
Nabo00o
I think Clarky is right, time might not be the direct source of energy but definitely the way to extract it.
What we call the virtual particle flux today is probably what the older science used to call the ether.
It can be tapped in many ways, we do not need direct power to extract the energy, we get it for free all the time! What we need however is to upset the symmetrical exchange of energy between that realm and the the physical one.  It is not impossible, and if we consider energy to be conserved in all four dimensions we can freely power everything we need without screaming perpetual motion.
Highly recommended reads:
http://www.overunity.com/index.php?topic=7693.0 Theory of vacuum energy extraction
http://alexfrolov.narod.ru/work.htm Practical ways of using potential fields to produce power
http://alexfrolov.narod.ru/net.htm  A series of really great magazines, covering many free energy subjects.
Naboo
Static energy...
Dynamic energy...
Two forms of the same.
EELRIJUE
Quote from: Nabo00o on July 16, 2009, 10:37:03 AM
Naboo
Clarky? Clark Kent...the overgrown boyscout? hahaha
:) ...we've been watching too much superman at our home...funny you would say that.
Any machine which is moving or non-moving in operation, such as like a solid state 'tapper' of the aether, will be perpetual in nature. Maybe not perpetual motion, but it will be perpetual in order to have over-unity gain.
We can use the time dimension to get free energy for all time. But we also need the other 3 dimensions in lieu of it.
"What we need however is to upset the symmetrical exchange of energy between that realm and the the physical one."
It's called symmetry breaking...and you do this through vibration. Vibration breaks symmetry all the time when it goes from positive peak to neutral...to negative peak.
Vibration will upset the balance between 5th and our local physics realm.
