On Frequencies and Fireballs
Started by darkspeed, September 26, 2009, 03:17:17 AM
Grumpy
Is the current induced by a traveling wave reversed like normal induction? (Lenz's Law)
Yes, this is a loaded question.
Does a traveling wave induce other traveling waves as it moves along an air-cored coil?
        -Frank Edwards
EMdevices
this discussion tread started out of nowhere,  can we have a diagram please, so we know what the set up is?
Also high voltage DC bias?   on coils?  This would mean a huge DC current (if resistance is just that of the wire)
EM
Low power frequencies combine to create a single pulse with an amplitude great enough to saturate the system and for a nanosecond disrupt the high voltage dc bias.
The advantage of using the frequencies in this way is to achieve a much more rapid ON>OFF>ON switching than could be accomplished with conventional circuits.
This rapid transition from ON>OFF>ON creates the radiant event that is collected
BEP
Current induced reversed?
No. A traveling wave is only group velocity of changes in density. This is why the effects can be superluminal. Mass cannot move faster than light but space can.
Group velocity is relative and can be used in math for a velocity with the same results but the results will indicate FTL.
Ex. Two loops with the same center axis....current flows CW in one and CCW in the other. Both currents have a GV of 1c.  The effect between them could be the result expected from FTL affects.
IOW:the current induced will be in phase with the voltage and if left unchecked heat could vaporize the conductor.
Just my little interlude from work 8)
sparks
    I believe that the space between an electron orbital and a neucleus is filled with wave energy.  The electron is always changing position relative to the neucleus which results in a continous repolarization of the field between the neucleus and the electron.  This causes a displacement current to flow between the two and a photon or photon packet is born due to the electron movement relative to the proton in the core.  The transmission of this tiny amount of emwave energy is lost in the chaotic emwave field creating our reality.  But if we can get all the atoms placed correctly so that the entire mass in question radiates superimposed waves then the energy density of our field becomes less chaotic and more predictable.   This radiant energy is radiated everywhere that a repolarization of space is occuring even if it is the space between an electron and the neucleous.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
BEP
Quote from: sparks on October 09, 2009, 07:12:34 PM
I understand that as:
Space is not a void. It is the medium which mass rides within. The only way mass can exceed c is if the space holding the mass moves or expands/contracts FTL.
;D
EDIT>>
This thread is a great honeypot but it is becoming a bit sticky in here  :D
