Tesla IMPEDANCE PHENOMENA - FIG 183C
Started by darkspeed, October 05, 2009, 03:42:12 AM
Grumpy
Quote from: darkspeed on October 10, 2009, 12:44:41 AM
Thanks
I will try the incandescent bulb.
I know it will fire a 120v neon nicely
I put a 63vdc cap between a shell and ground, no diodes, and it does charge the cap.
I have it cycling slowly but every time it fires the meter shows the cap charging.
Only works when shell is cap+
Human nature is hilarious.
You charge caps straight out of the gate, the "pièce de résistance",  and everyone else is google-eyed over at Otto's Geheimnis Stube (Mystery Lounge)...classic...
If you use negative pulses, the shell should become negative and this is far more important than it sounds.
Try the diode thing too.  Worked for the Russian that invented it.
        -Frank Edwards
Grumpy
I just ran to the bench and threw a bunch of stuff together - not optimal - pretty ugly.  I can put some charge on a non-electrolytic doorknob cap (about 140pf) on the shell (my shell is fine mesh - using my Ed Grey left-overs) with the other lead of the cap to ground.  Enough to get a small spark.
Electrostatic action to a moth's wing is very nice - same as styrofoam - at the shell.
So, if the cap has to be grounded, is this just capacitive coupling?
        -Frank Edwards
EMdevices
nice work darkspeed, I'm impressed.  Looks like you have resources including time on your hands, and your puting it to good use.
EM
darkspeed
Quote from: EMdevices on October 10, 2009, 02:17:09 PM
EM
Thanks!
darkspeed
Quote from: Grumpy on October 10, 2009, 10:07:38 AM
Today Im going to flip it around and pulse the other way as a test.
As well as shell > 10:1 > cap >ground .. see what I get on the secondary
I already have a 7.5kv standard (not sr) on the negative side alaruski... may need a faster one..
