Steven Marks secret
Started by otto, October 07, 2009, 12:26:21 AM
EMdevices
@IceStorm,
you're so correct,  at a wavelength of approximately 50 KM,  1 meter is VERY NEAR to the source.  We are definitely in the near-field.  Look up the concept of tuned magnetic loops for VLF.  This technology is being utilized now by wireless power folks.
EM
IceStorm
Quote from: EMdevices on October 12, 2009, 01:55:39 AM
@IceStorm,
EM
EMdevices, pls do a simple test,it take 10 sec to do. Use a spectrum analizer and look at the highest peak in the VLF range. Where im at right now the highest peak move from -20 DBm to -54 DBm , since its in DBm you can easily see how much power you can extract with a ideal LC Tank. Now tell me how i can light a resistive load instantly with that so little power ?
Best Regards,
IceStorm
Mannix
So when he said that the devices work in aircraft, that must have been an aircraft skimming the power lines? at 10,000 feet?  so it was a mountain power line
Even if that is the case it would revolutionize the way we distribute power.
Some how I think the radio guys ..like myself would have done this. I look forward to you sharing the results of your hypothesis. Meanwhile Otto has shown you something that may be so very important.
Just try and make a little  tiny coil jump with 200khz drive and buzz at 5-6 k.
I havent succeeded yet but we will work this little bit of the puzzle out
Interesting times, whatever your take on whats been put foward.
forest
I'm wondering. Is that the same effect when I switch my hair-dryer ? The lights nearby blink. Surprisingly the same effect occurs when I turn off dryer or when I change rpm by using switch.
The obvious test would be to compare light bulb without inductance with a dryer with inductance. Heat both and abruptly shut off power. Because both were heated temperature would have no difference to the effect.
wings
Quote from: Mannix on October 12, 2009, 06:41:55 AM
http://cosmic.lbl.gov/SKliewer/Experiment/DataAnal.htm
