Steven Marks secret
Started by otto, October 07, 2009, 12:26:21 AM
sparks
   Nice work Wattsup
Grumpy gives us another tidbit.  Homepolar generator.  Bearden would say rotating frames bend spacetime.    But the rotation needs to be relative to something stationary.  Like the axle of the homepolar generator and the observer brush.  They both need to stay in flat spacetime along with the load.  So if your rotating the aether or putting a depression in the spacetime grid what does that do.  This has been experimentally verified many times by many scientists.  What happens to massless pure inertia we call photons  or emwaves when it encounters a bowl in the flat spactime grid?
What happens to a kid skateboarding a bowl?  What happens to entire Solar Systems when they encounter a major depression in spacetime?  ENERGY GETS SUCKED IN  Photons alter their vectored stream.  Light is bent.  Gravity is created.  Time is altered. Event horizons are created.  Negative entrophy.  Cold radiation. Shit that was happening here in observable radiated 3d time now happens somewhere else or at some other time.  I have felt this happen.  I felt myself radiate cold.  Happened in a highvoltage dcpulsed field.  At the very least the 50watts I was using was one hell of a good refridgeration system.  Kelvin would have loved to have been there.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
EMdevices
Quote from: Mark69 on October 19, 2009, 07:23:15 PM
what happened to SM?
SM was bankrupt and lost his Spherics business, and now lives in California in a semiretired financial situation.   His seemingly "free-energy" device we call the TPU, was unsuccessfully peddled by others, and the few "rights" he had to it were sold to some guy in the Philippines, who never did anything with it either (because it doesn't work farther then a few feet away from power lines that carry HIGH CURRENTS).  But SM is alive and well and can curse up a storm if you piss him off.  Just listen to the voice message he left for Jack.
EM
sparks
   The tpu intrigue.  What an inspiration to us all.  We know we have somekinda magnetic field rotation.  We seem to be neglecting the polidial field.  The plastic the black tape stuff.  Tesla made a neat coil.  He matched the capacitance and inductance of his coil so that any resonant activity didn't have to go too far.  His bifilar pancake coil was a tuned resonant circuit in and of itself.  Each turns capacitance and inductance matched perfectly.  The input pulse stored in the coil never needing to loose power like when you have an rlc tank.  Very little resistance when the current isn't flowing anywhere.  Resonant circuits store highfrequency vibrations and are capable of converting hf low amplitude inputs into low frequency high amplitude circuits to drive motors and stuff like that.  What frequency was Tesla tuning into when he drove his Packard around.
Infrared antennae tank and frequency converter would be nice.  Now instead of dumping the carrier you store the carrier in a tank.  Pretty soon your microvolt potential is in the 100's of volts.  Energy is conserved as you take it and dump it out slowly in a 60hz signal.  The current capacity all depends on how much mass you have in your collector antennae.  If each atom of your antennae shakes of an electron you need one mole of atoms per amp.  To drive a car around you need 30kva for any kinda performance.  Say you have the motor rated at 500volts you will need 60amps.  So the antennae is going to have at least 60moles of easily ionizable atoms.  Hmmm. Or say there is a gas involved that is already ionized which is in evacuated tubes but acts as a charge carrier. Then you might get away with 12 rectifier tubes filled with ionized gas as a receiver of highfrequency low amplitude vibrations.
Think Legacy
Spread the Love
giantkiller
@wattsup,
What if the magnet was a poled keeper to 2 steel or iron posts with another magnet as a keeper on the other end. You would have a broken PMH till you put the top magnet on. Then the magnetic current would flow. Eh?
@sparks,
In the void of space between galaxies, protons abound and electrons are far and few between. But in a gravity well, like a galaxy where there are huge magnetic interactions, we have an abundance of electrons. When the protons and Flux meet we get electrons produced by the interaction of forces.The outcome are waves, standing waves which are electron shells. I got this today from subquantum kinetics.
--gk.
Grumpy
Quote from: wattsup on October 19, 2009, 08:16:32 PM
@Grumpy
Good points but the voltage did not drop to zero, but to 12 volts. I also thought about a diode, turn over, internal current reversal that can't go through a diode and the meter reading falls to nothing, but to 12 volts, why would that be if there was a diode blocking the output?
Just got my manual for SMs meter. I'll look it over and report anything major.
12v battery - then magnified - magnification stops when flipped - remember this is the bifilar method
12v could be a bias too
        -Frank Edwards
