Steven Marks secret
Started by otto, October 07, 2009, 12:26:21 AM
wattsup
@Grumpy
Yes, I agree, the 12 volts is the base, the magnification stops when turned, and it increases with the magnet on.
@GK
The only other magnet I could consider in the FTPU is the center toroid core itself.Maybe that would explain why SM did not want guys with pieces of metal near the toroids. But I do think your idea is very plausible.
@sparks
I think I discovered something else.
A few days ago I was watching a documentary on Peregrine Falcons. Good doc with great images of them when they fly real high up, spot their prey, then suddenly free-dive at 200 mph and hit their prey to knock it out, then return for the feast while the prey is in a daze state. Everything went very well until I saw a close up of the Falcons' nostrils. And then the SM analogy of finding the reason for Mach flight hit me. The nostrils have an inner cone. Without it, it would be impossible for the bird to breath at such high speeds. In fact this was the basis for making the cones on the air intakes of them high fly'in Mach machines.
Now consider again, we, I, you and your TPU is traveling 67kmph through universally present ether. How can you drag in ether at such speeds. Well a center toroid could be your center cone and the rings are your outer nostrils.
Those aviation engineers new that they were traveling through different densities of available air so they had a basis to start making calculations. So what do we have as a basis to make calculations as we and our Earth dives through space every second. We know the Earth pulses at 7.8, but what is the frequency of the Earth travel in space. What relation does this have with 5000 hertz. So what do we have. When we are born, we each get a free 67kmph travel ticket for life. That's it? No, there is more. We can add as a bonus, the speed of our Earth rotation, plus the speed the sun moves in space and drags our solar system along, plus the speed of our galaxy moving away or closer to other galaxies. If you add up all these speeds, and if you consider that all mass on Earth exchanges ether sites at such a speed, how can we take advantage of all this potential energy?
Luckily, ether is everywhere so it does not have to move, like air does not have to move. We have to move through ether, like water has to move through a turbine to turn a generator, like the Falcon has to move through air to make his kill.
What would knowing the frequency do. Well, you know when they hire these construction noise reduction companies because they are getting noise complaints because of incessant jack-hammering. Well they come in and play frequencies that will cancel the ambient noise, or mask it, like maybe shadow masking. Ring a bell. If you know the frequency of your travel through ether, and you can pulse at that frequency, you will neutralize the effect of the travel in that particular space, creating what. I don't know. Man. That I don't know.
forest
Maybe FTPU was simple and had only one collector on top.Effect was produced on top so when device was turned down collector was out of field.
Later SM added second collector, so there was two of them : one on top and one on bottom.Just an idea.
Grumpy
Could SM be rotating a magnetic vector potential?
The following field properties for an EMF induced by a changing magneitc vector potential are taken from Hooper's work with motional electric fields:
Field Properties:
(1) Spatially distributed energy
(2) ØE = ds
(3) Curl E
(4) ?ab E = ds
(5) E =dV/ds Potential function
(6) Behavior with respect to shielding
(7) Div. E
(8) Poisson's fundamental law with respect to the interior of conductors
(9) In conductors carrying current
(10) Inverse square law
(11) Spatial nature of field
(12) Relation to charges in it
(13) Field dependence
(14) Functional dependence on velocity.
The electric field induced by a changing magnetic vector potential: Et = -dA/dt ~
(1) KE2/8 pi ergs/cc
(2) / 0 in general
(3) = -dB/dt
(4) Not a constant. Dependent on the path of integration
(5) No
(6) Can be shielded with sufficient thickness of shielding
(7) = 0 always
(8) Not obeyed
(9) Can drive a current without a potential drop along the wire
(10) No
(11) Continuous throughout space it occupies
(12) Charges within it do not distort the field
(13) Dependent upon another field
(14) ---.
        -Frank Edwards
Doug1
This topic is riddled with speculations and theories some are even interesting. Mylow could have had all this if he was better at hiding the fishing line.
In the end if something can work to provide self sustained power it will be simple in action then humanized and turned into a mess. How ever it will have to function in it's basic form "simplistic". An act of leverage using an event or effect that exists in the natural cosmic plan of existence. A type of transformer with a duality. The lack of results would suggest that a change in windings is in order to make a more dynamic action far beyond a bifiller or a rodin.
  "all those small wires add up"
Maybe the small wires are not even in view or detectable in any way. What leaves the load and goes to ground needs to have enough punch to cause the action or reaction to sustain itself and then some.Enough to require control to keep it from eating itself or burning up. Fits in a very small space or can be hidden within a part of the construction or is by it's nature an addition to the construction but not in plain sight and produces the physical feeling of a gyro. How many directions does a gyro move in? It toke 6 months to build? If he was working in the micro wave band and had to tune it just right maybe it was making him ill and required many breaks between working on it.
Mark69
@ wattsup,
concerning your sound eliminating idea, I remember way back in physics class we did an experiment on this.  We hit a tuning fork over a long tube of water, where there is a certain distance from the fork to the water.  We could bounce the sound waves off the water back to the fork, which caused the cancellation of the sound.  Though also, which I think will help this case, changing the distance from the fork to the water we were able to MAGNIFY the sound wave and make it louder.  Perhaps this is what is happening in the TPU as well?
Also another question I have or solution, maybe an obstacle is that the wire is braided and you cant keep an exact distance because of this.  What if you you unbraided wire more like house electric wire?  Was braided wire originally used?
Mark
