Steven Marks secret
Started by otto, October 07, 2009, 12:26:21 AM
wings
Quote from: stprue on October 21, 2009, 04:36:47 PM
Yes I know and I'm sorry.  It didn't copy!  It is clearer if you Wiki it that's where it is from.
my hero Giuliano Preparata:
The essential result can be stated as follows. An ensemble of a very large number N of particles, can assume two different configurations and are coupled with the e.m. field (as every particle made up of charged components, for instance atoms and molecules, does), enters a coherent state when its density exceeds a threshold and its T lies below a critical value. This coherent state has an energy lower than the original gas-like state; in the coherent state the particles oscillate between the two configurations in unison, in tune with an e.m. field grown up from the vacuum fluctuations and trapped within the assembly of coresonating particles. This coherent regime of both matter and e.m. fields holds within a region of space whose size is the wavelength of the e.m. oscillations; this region is called "coherence domain" (CD) and its size ranges from a fraction of a micron for liquids and metal electrons to some microns for solids to several tens of microns for ions in solution. ….is then the sum of two mesoscopic components, a coherent fraction made up by a large number of CD's and a gas-like non coherent fraction made up by particles filling the interstices among CD's. CD's are able to establish bounds among themselves through the tails (evanescent fields) of the quite intense e.m. fields existing inside the domains. So there is a large cage of the CD's within which there is a definite phase and zero entropy, trapping a "gas" of non coherent particles, (EDG)
dead ... involved in cold fusion
http://www.newenergytimes.com/v2/views/Group1/Preparata.shtml
otto
Hello all,
@thishatang
have I seen this schematic on the energetic forum??
The schematic ....  gave me some ideas, thanks.
A few minutes ago I was watching again SMs open TPU video.
With sound and without sound.
Otto
giantkiller
@wings,
An excellent purpose of cohesion through density.
Thanks for an excellent post.
--gk.
IceStorm
Quote from: tishatang on October 22, 2009, 01:12:06 AM
@Otto and All
Do you suppose SM could have used something like one of these self-powered radio circuits shown here:  You could put one of these in front of each of the two coils.
http://www.crystalradio.net/crystalplans/
Scroll down to #153 Free Power Radios.  Here is page two of three showing the circuits.  File too big to attach.  You will have to download.
http://www.crystalradio.net/crystalplans/xximages/Free2.JPG
If one coil is tuned to around 200Khz and the other coil is turned to 60 hertz, they might gain in power like you would pushing a swing?  One circuit is designed to capture 60 Hz and the last one good for all stray frequencies.
Tishatang
Do the Math for the amount of copper needed to make a 60hz LC Tank after that look at ALL video of SM, forgot the biggest one. The size is too small to fit the LC tank and since there no Core imagine the size of the coil loll 60hz resonant LC tank air core LOLL.
Best Regards,
IceStorm
sparks
In the ftpu sm places a magnet near a coil.  He does work.  He changes the magnetic field about a conductor and surer than sugar he generates voltage.  Now he flips the magnetometer over and again generates voltage.  Isn't that what an alternator does.  Move magnets near coils?  Electrons will orbit around a magnetic field line as will protons.  This is what causes induction.  When you change the magnetic field lines in a plasma (copper is a negative plasma) the free electrons rotate about the magnetic field lines.  As you concentrate the magnetic field lines you increase the chances that the electrons will collide.  These collisions result in a current of electrons until the magnetic flux lines become unchanging.  When this happens the collisions continue for a while then cease as the electron field settles down and everyone is happy spinning around near it's neighbor.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
