Steven Marks secret
Started by otto, October 07, 2009, 12:26:21 AM
Magluvin
Titoroni
http://www.youtube.com/watch?v=48E_72WGulk
check out one of my vids here.
Does it seem i might have some of the stuff I need?
Magnuts
Tito L. Oracion
Quote from: Magluvin on December 09, 2009, 04:02:58 AM
Titoroni
Magnuts
here is what you need zenerdiode, coil as resistor, coil as caps, coil as source of input and galvanize wire, then everything is coil for collector and coil for kicker, speaker wire, coax.
see how coil is amazing?
Magluvin
Tito
All coils?  Galvanized wire?  Hmmm. Not sure what that wire means. Copper wire with galvanized coating? I have seen some things that talk about steel coated wire. But im not sure what that is for yet due to no explanation there.
i have tried coils in series and different things, but they seemed to impede any progress. Anyway, I know you are going to remain secretive. But thanks for the talk. =]
Magluvins oven
forest
The mystery is here :
There are two LC resonant circuits : parallel and serial,right ?
he he, not really. IMHO there is only one and you got it when connect capacitor and coil and it wants to oscillate always but cannot overcome resistance- friction.The problem is our connection , it has to be only a push at right moments be we tend to connect LC circuit to power source which is not in balance with LC circuit.
Ok, once you find a way to accumulate energy in Lc resonance you cannect antenna to it and see how ambient electrons dance.
Tito, you should be more clear in describing actual methods of putting those ambient electrons to do work. In other words : output stage.
Gobaga
Quote from: Tito L. Oracion on December 09, 2009, 03:40:19 AM
of course part only but it is the main working engine, it depends, its up to you if you want to make it big proj. like for example you want more watts off course you need more coils in magnification.
all we need is to make a strong moving electrons then everything is gain.  8)
In regards to the Ozone patent and associated circuit:
When the cap discharges through the primary coil (M), are the coils for the motor (D and F) are also connected to the power supply?  If so, this switches the HV from the capacitor (L) over the low voltage from the power supply.  What does this do?
