Steven Marks secret
Started by otto, October 07, 2009, 12:26:21 AM
stprue
Quote from: giantkiller on October 10, 2009, 02:26:01 AM
How to achieve the oscillatory, ringing feedback:
When the fet turns on the magnetic field appears on the bias line.
Then the field appears in the red control,
then the field appears in the blue control.
The 2 control coils are bifilar and wound like a Telsa bifilar pancake.
So the bias gets squeezed by the first control then the secondary squeezes it again.
The collector is biased with the initial field and then echoes the shockwave to the gate in parallel with the incoming pulse.
The control coils go all the way around the ring.
The collector coil is stranded lamp cord. The bifilar control coil is solid 22awg speaker cord. The diameter is 4".
Schematic included. Starting frequency is 4khz. Ending frequency is 1.6MGHZ.
Watch the video and see the effect take hold and continue.
http://www.youtube.com/watch?v=0C1uicaW7Ms
This set up is stable. The results happen every time at about 20 seconds.
It is a good time to be alive.
--giantkiller.
Awesome!  Thank you for making the video, it really gets the concept across!  Keep up the good work!!!
Grumpy
Quote from: EMdevices on October 10, 2009, 12:39:29 AM
Yes, this is a jungle, so get a good machete and clear your path....
Darkspeed is hacking through the jungle...
http://www.overunity.com/index.php?topic=8134.msg204174#msg204174
        -Frank Edwards
wattsup
@otto
It is good you opened this thread. Remember during the ECD days, I had put up a diagram mod of your plan putting the switches on the positive side and trying to explain that pulsing an already full coil at the end is not the same thing as pulsing an empty coil at the beginning. Glad to see you have found this out.
OK, I am putting up a diagram using your "right" diagram as the base to show how this may come together in the FTPU. In a basic form the FTPU is two Tesla Ozone Patents working in tandem via the toroid coil.
@EM
First of all @otto already said his diagram is not complete which is very understandable. Anyways, we are all subject to many forms of negation any time we put something forward. It is part of the deal so no problem. We each bring forth what we can within our own limitations. In my case, I am finding where things go but I will never have the ability to actually calculate component values given my lack of EE. But did that ever stop me from helping. I think not.
Yes there needs to be some voltage regulation since just in the FTPU there are many capacitors. I am in the process of finalizing a 3D diagram of the FTPU that will show you the better relationships between the rings, control coils, toroid, and components. I need a few more days to maximize the new diagram.
As far as resonance goes, this is a given since it is one of the only ways to ensure the lowest power consumption of the total device, while working to produce more juice at the output.
@GK
I have seen this many times in my testing where the waveform suddenly morphs into something else after a short while. I am glad to see you showing this.
@About the diagram
Here you will see a rough vulgarization of what i have been trying to convey for some time now. If you take two of @ottos' "right" diagrams and complete each side with the Tesla positive shorting method, you will get something like shown below. The two power supplies are actually only one power supply and the one lead going to each from the secondary outputs is basically one polarity and another polarity. The lines going back to the transistor bases are simply to show that the system is interdependent. One first side pulses, generates an output that is used to pulse the other side, that generates an output that is used to pulse the first side. There are capacitors in between these as my final FTPU diagram will show but again, I cannot calculate those values. My work is more limited to the actual physical make up of the devices, my own small testings and some logical portrayals.
EMdevices
It's as simple as this:  you connect your so called "TPU"  to a power supply, and you automaticaly prove you don't have a TPU, period !
Watch the videos again !!!
EM
giantkiller
@EMD,
Exactly! Next is to connect 2nd and possible 3rd stages for building the energy to a usable power level then feed that back. Just like a stungun.
If I connect it to a battery that makes it a valid TPU? I can do that. This runs on 12v volts now. I have the Bedini type engine now. Add a power battery and a charging battery. Guide the energy to what purpose needs to be done.
The energy as it stands now will only phantom charge a capacitor. You know, high volt reading and can not run anything. Been done too many useless times. It is only a start. But thank you for realizing this as a TPU or close to it. This setup will continue as a basis for added simplicities. After 3 years we all know the next steps. The subject has been raped many times over.
I have given complete instructions for the builds that amount to something.
--giantkiller.
