Steven Marks secret
Started by otto, October 07, 2009, 12:26:21 AM
0 Members and 20 Guests are viewing this topic.
giantkiller
Here is the corrected model.
And the version that matches the stun gun feedback.
wattsup
@EM
Yes, your ring looks very promising and I still have mine and I only hope your are totally right that it could be so simple. It could actually be used to do away with the starter battery. That would in itself be a major coup so please let us know more. Please stop being so frustrated with us. You know we have to investigate all angles. What your video showed is major major major. I would like to know if you wound a control coil around that loop will the ring still work as it does. Also, if you put a small load across the newly wound coil, will the ring again do what it does. Also will a tighter control coil wind kill the ring effect, making it essential that the control coil be wound over with good open spaces in between each wind, like the FTPU. Hmmmmmmmmm Thanks for the video.
@GK
In your diagram, what would happen if you put a diode between the D and S of the IRF840 (love them buggers), pointing towards the source for return flyback.
Also, I don't think the control coils (CC) should be in series with the collector ring(s) (CR).
Maybe do one test.
On the S of the IRF840, connect any coil of high inductance (CHI) (could be a toriod transformers secondary wind). You have two rings so connect them in parallel but one side of one ring to the other side of the other ring and same for the two other wires. You will have then two wires for the rings. One the other end of the CHI connect one end of the rings and send the other end of the rings to ground. Connect your CC in parallel and connect to a bulb. Now pulse the CHI/CR and see what the bulb does.
@Mannix
We'd need to know some more about what @otto is seeing.
kooler
howdy
has anyone here tried discharging a cap thru a coil of bifillar wire ...
atleast 6 or more hz...
and bridge your second wire to a small cap to read a voltage
just wondering...
otto
Hello all,
Im sorry that I cant answer to your PMs. They dont work. I hope under my profile is now my internet adress so you can use it.
I can only hope that I can this week make a video to show you what I see.
Yesterday I have finnished 1 oscillator that gives the needed vibrations. Today I hope to finnish the 2. oscillator. With this 2 oscillators I can have a lot of fun and burn them again.
The problem is that when I hit the exact same frequencies I see the current and voltage from the power supply rising until something is blown.
Otto
forest
Quote from: otto on October 14, 2009, 01:01:07 AM
Hello all,
Otto
Power supply ? I thought you are using battery ! And I think oscillator should have some protection method to do not let spread that vibration on it. Maybe small circuit powered by separated small  9V battery ?
Everybody : try to use transil across S and D of mosfet. They are wonderful spark gaps
