James Roney's breakthrough: Runway Plates
Started by Cloxxki, October 15, 2009, 08:53:55 AM
carbonc_cc
Here is another update I worked on last night...
http://www.youtube.com/watch?v=W-dIuBg-EAg
Interesting result with the batteries.  The field strength was quite weakend on the outside of the battery.  If I had a peice of wood the same thickness, the flux lines would have been much stronger.  And if I just used a peice of metal the same thickness of the battery, I'm sure the field strength would have almost been the same as just the magnet alone.
FatChance!!!
James has put up a new video on his "improved" Runway Plates.
http://www.youtube.com/watch?v=ldKfHX__5Hw
When seeing his new design I wonder if he's not fooling himself in his conclusions.
He seems to believe the acceleration effect will remain once he completes the
wheel with all the magnets all around.
This has been tested over and over in various designs. Once completed it's a No-Go!
Last attempts on this type of motor was using the Tri-Force Magnets.
And as usual it showed acceleration but only as long as the circle wasn't completed.
If James got something new here I really hope he makes it into self running under a load.
By load I mean a connected generator capable of doing work, e.g having a small lamp lit.
spoondini
What happened with his previous 'cutting edge' stator?  No comment there.  But this one will wok?  Looks like 1000 other attempts I've seen (and personally chased with no results). I just wish that when folks chase something that they find doesn't work that they would clarify.  In roney's case, it's clear his last runway plate didn't do what he expected, don't think this one will either.
Rapadura
Never use magnets on the rotor when you are using magnetic shielding in the stator, because magnet shielding is metal plate, and magnets (on the rotor) are attracted to metal plates.
If you're using magnetic shielding in the stator, use simple steel balls in the rotor. Steel balls aren't attracted to metal plates.
FatChance!!!
I strongly believe James Roney's runway motor was a dead fish in the water.
He made several attempts and got strangely exited over small and weak movements
but none could ever self run. His best result was approx half a turn by hand induced force.....
