James Roney's breakthrough: Runway Plates
Started by Cloxxki, October 15, 2009, 08:53:55 AM
happyfunball
Quote from: gadgetmall on October 22, 2013, 12:28:49 PM
For your information this is the real deal. The secret holy grail magnet exist as he stated.. Naysayers did not build i t only speculated. The flux is strong on one end and diverted. On the other. Grab the videos before they are taken down a 4th time by youtube. https://www.youtube.com/watch?v=XePk5ECrs0M&feature=youtube_gdata_player
I followed Roney's videos. The last one he made was of a horizontal wheel on a table with one or two sets of magnets mounted, and an external shielded stator. He thought it showed proof of the viability of a permanent magnet motor, and claimed it would work once he applied the rest of the magnets and several more stators. That was the end of the Roney story, no more videos after that. it obviously didn't work. This is not about any sort of suppression.
gadgetmall
 His videos were pulled Three times and he has health issues plus a 10 hour a day job.. He has proven without a doubt a modified magnet that directs only One way on one end To pull other magnets on his wheel past the stationary stator magnet .   https://www.youtube.com/watch?v=XePk5ECrs0M&feature=youtube_gdata_player
This allow him to demonstrate not only gain but the main thing no sticky spot. https://www.youtube.com/watch?v=-gJd1RctfwM&feature=youtube_gdata_player
He also proved that is not merely the weight of the magnets and gravity producing the gain. By placing his wheel on its side. He has other videos which are completely open source his experiments which are Shown without trickery. And fully explains his success in one way flux channeling of his stator.Most of his videos are current and this year.Some are reuploaded and some are new . I see all his magnets being pulled way past the stick point because of the trailing flux difference he created ./
gadgetmall
Hi TK,
I do realize the research you do is very valid.. Most of his videos were posted this year and it is true they were pulled several times for unknown reasons for years. For sure no copyright infringement.. We all have experimented with magnets and shielding the back end.Or theoretical balanced state or unity of a magnet. In one way or another however this. One video with his. Teardown of his specialized way of creating A bend of the opposite pole and the angle at which it sits in relationship to the. Wheel magnets is quite ingenious and simple to replicate. That is why we ordered all the exact components because. I do not believe he is trying to. Sell anything or get hits or even care to convince us one way or the other. He. Shows a. Very good demonstration. And follows suggestions by making new videos with the suggested comments  He has mentioned that he does have a. 4 stator self propelled model. We can clearly see his single stator slings the magnets past the stator. 12 spokes without using any of his energy other than letting the wheel go at the point of the leading magnets pull toward the stator.. What seems very convincing is he also shows what a non shielded magnet does at that same location. It sticks as ss expected at the last magnet. His method of shielding. Appears to really eliminate. That stick spot. By the combined attractions slinging it past. I watched all the videos he has and i believe. He has done it. . This demonstration. Here shows the slinging. Past one. Roney stator. Now picture two stators and three. And 4. https://www.youtube.com/watch?v=-gJd1RctfwM&feature=youtube_gdata_player
We realize the condition we need is a perfectly balanced wheel with the least amount of friction to make this work.  By magnets alone. We. also realize one wheel can be multiplied in parallel for more power. Not necessarily a bike wheel but flywheels might be interesting.
Gadget:
I watched the first two clips and sorry to say I did not see anything.  The stronger end of the magnet will pull in _both_ directions as the magnet array passes by.  It will speed up and slow down the wheel equally.  It doesn't matter that he made one end stronger.  Do you follow me?  It's clearly happening in the clip.  In the first clip he demonstrates the wheel shooting past the sticky point on the rebound a half dozen or more times.  That's exactly what's supposed to happen because the rebound has more energy in it than he realizes.  He always pushes the wheel to start.  Then the wheel falls into the magnetic potential energy well and speeds up.  The wheel hits the "backboard" with _two_ energy components, 1) being at the top of the magnetic potential energy well, and 2) the initial velocity that he started the wheel with.
So when the wheel bounces back, it does the dip into the magnetic potential energy well and then emerges at the top of the well on the other side.  At this point the wheel still has one remaining energy component, which is 2) the initial velocity that he started the wheel with being reflected back from the "bounce" off of the "backboard."  That's why the wheel sails past the sticky point.
If you understand that then you should hopefully agree with me.  But I can't twist your arm....
