Understanding electricity in the TPU.
Started by wattsup, October 18, 2009, 12:28:42 PM
Mannix
It happens when i run a frequency of 30-35 k into my 15" ring of lamp cord not connected bifilar, it does not seem to matter how many turns but i probably do not have the right value any way but whenever reach that frequency the phase seems to waver, very slightly like em said but mine was alw3ysa very minor. I only used parallel caps when mucking about with it .It was really designed as a test to check the numbers given . It is at one specific frequency but changes slightly with different size rings ..it at 220k as well but less I have not yet hooked up in series like em has done but I am doing that now. It is was  a slight wriggle but  Steven said it was important but would not say any more .
I was using a pure sine generator (a very  old Siemens communication line sender unit with 600ohm output)
perhaps your "feed back" was from your coax leads I dont really know but em has what you have it seems. But with a slightly different method that seem to be enclosed wit the loop
he has a square coil ..i wonder about that too  we will see
My work with your circuits did not get the same results that you are getting its the why that is confusing to me right now.
otto
Hello all,
@Mannix
when I slowly tune a frequency I see 3 "break points" to say so at 245kHz and around 30kHz and at an unknown 3. lower frequency.
As I slowly tune a frequency from 500kHz down to 245 kHz  the signal suddenly jumps, is bigger and the frequency changes to a little bit lower value. The jumps are in the horizontal direction on the scope. Something like the particles are pushed in the horizontal direction.
The same at around 30kHz......
I see the same at a much lower, wrong frequency and I managed it to get the vibrations. Very dangerous!
Now imagine to tune the frequency to this "jumps", "breaking points". Result: vibrations. Very strong vibrations made only with coils. I dont use caps.
Hmmm....again the same s..t: I have blown my oscillator. Not the first time, not the last.
Otto
Mannix
Nikola Tesla
Quote from: Mannix on November 23, 2009, 06:17:56 AM
Yellow seems to be high frequency..from these people at least
http://www.surplussales.com/Inductors/FerToro/FerToro-1.html
Color does not say anything.
It can be diffrent when you order somewhere else.
innovation_station
@ em  :)
now i know you got this down ... ever try open ends?  ;)
a little diffrent on the tuneing ..  you want to tune to the cosmos.....  ;)
this then becomes orbit ...
i can set a cap into oscolation from 1 pulse ...
i would like you to check it out ... if you get time !
i then circulat the spinn as the engery passes in and out of the cosmos ...
close to mpi only better  ;D ;D ;D ;D
william
this is exactally how your shock ya's work  ;)
of course the t sheild enhances this effect ...  humans only get 7 stones ...!
RA THE GOD OF THE SUN  ;) has 8  i need 36  ;)
btw i can sub stones for humans .....  ;) :D
it is possible i only need 24 ...  need more reserch ...  left that in dust 4 now ... ya know ...
other more important things need fixed first!
