Understanding electricity in the TPU.
Started by wattsup, October 18, 2009, 12:28:42 PM
smoky
@wattsup
I hope you don't mind these thoughts on your TPU video....
I think your setup is acting as an antenna from the 17.8MHZ hot feed side (the shielded coaxial outside always remains at ground potential anyhow) unless poorly matched. The signal is capacitively coupled via your windings around the conductor it gives the benefit of raising the generator feed impedance so not much capacitance required. As the TPU coil you wound is likely a poor match VSWR wise to the feed impedance at 17.8Mhz, the travelling forward and reflected signals are summing producing enough of a high voltage antinode for you to pick it up in a shorted turn loop antenna and rectifying it via the polarized LED. To give the illumination.
Energy dissipated in LED vs generator feed power wise it's hard to comment without first measuring the forward & reflected power with some sort of directional coupler or slotted line VSWR setup .
Gerry
wattsup
Quote from: otto on April 07, 2010, 04:03:26 AM
Hello all,
@wattsup
nice videos!!
Your idea is something like to split a TPU into a positive and a negative pulsating "system"?? Top "half" of the TPU would be positive and the bottom negative pulsed??
Can you post a schematic for us so we can easier understand what you did in the last video?
Otto
@otto
You have understood it well. Then the second wire on top half would then receive the negative bias from the battery and the second wire on the bottom half would receive the positive bias from the battery. The circuit is never closed. You do not have to because between them is the Earth's magnetic field all the time.
The good part is the battery end never goes down because they are only providing a bias and the pulsing end is never destructive because the circuit is never closed, hence amperage is at a minimum. You just have to find the right frequency whic is definitely not the resonant frequency but slightly off.
Resonance is like a fine liquid electricity that fills the coil with a steady non-changing EM field. It just oscillated at a very fine way. You need the turbulence of being off the resonant frequency. The pick up coils don't like resonance but they love turbulence.
In the FTPU video SM says 5k hertz but that is bullshit. Nothing will happen in there at such low frequency because the TPU is so small with few windings. Based on my tests with different coils, etc, he is more like 5 mega hertz but he would never say that because he was afraid of getting his ass whipped by Mr. Big.
I will make a diagram. Tonight I will make the FTPU build with a center toroid included and you will see the voltage rise to 60 volts because the toroid core will act like a tank. lol
My current build is simple to replicate and you do not need the exact coil turns, etc.
No one mentioned in the video about the scope shots. I indicated the probes were at 10x (hello) and the Volt/Div. 5 volts at Time/Div. 1uS. The output was showing the waveform on 6 divisions. 6 x 5 x 10 = 300 volts @ 1uS. lol
The battery consumes nothing and the pulse is 16.5 volts at a few micro amperes.
How clear can that be????????????
forest
We can have two currents in coil , right ? Each one related to its power source.
isn't that like vacuum tube ? like something Steven Mark said ?
do you see the difference when both are abruptly removed ? ;D
stprue
[A author=wattsup link=topic=8185.msg236644#msg236644 date=1270646729]
@otto
[/quote]
Wattsup this is amazing I cant wait to see your next vid!  I want to replicate sooo bad!  I have been testing pulsing coils and I can confirm most of what you said!
wattsup
@forest
Read my second post above. I just talked about the Tube and SM.
"do you see the difference when both are abruptly removed ? "
Don't know what you mean.
@All
There a billions of frequencies out there. Many will find their right place. There is even a frequency that makes you tick. Your own frequency. But, most are never used or required. You can build a circuit with 10 totally diffierent coils all in series, and out of the billions of frequencies, you will find one that will resonate them all together. It is the law of infinite possibilities. I can only imagine in the higher mega hertz or even giga hertz range what we can find.
I think that is what Leedskalnin was doing. He found the resonance frequency for the rocks he was lifting. Resonance maybe makes them lighter. I am just curious if the site also had ground achors here and there because if he was lifting one rock, others around it would have lifted also and would have to be achored. Sounds crazy but those big chains were not enough to pull a huge rock but they are perfect to hold it down.
