Understanding electricity in the TPU.
Started by wattsup, October 18, 2009, 12:28:42 PM
smoky
Gotta agree there.... his post above is irrelevant and off topic!
Tito L. Oracion
Quote from: wozlzl on April 07, 2010, 09:34:27 PM
No matter wow power leveling the precautions you take, there wow power leveling is always the possibility that you will world of warcraft gold find yourself in a threatening situation. There are gold in wow ways to protect yourself, but wow gold eu you have to be prepared. Carry a self defense product wow gold chea to defend yourself in any dangerous situation; there are wow cheap gold many excellent options. Take, for example, cell phone stun guns. These look just like the cell phone best wow gold you use everyday, but deliver several hundred thousand volts of electricity when used, rendering any attacker completely incapacitated.
This is the most WOW MORON i've ever read.  ;D ha!ha!ha!ha!ha!
I think you shut your WOW mouth.  ;D
Now i think i know now the effect of very high voltage. ;D ;D ;D lol
otto
Hello all,
@wattsup
try to connect your setup so the negative "part" is on the bottom and the positive on top.
The 5kHz is NOT a pulse frequency!!! Its a "product" of 2 much higher frequencies. Its really not a bull....t. SM was right about that!!
I tried your setup yesterday but no success because my brand new battery had a big problem with one of my TPUs and is now .....shorted, so I have to buy again a new battery. It was a 12V/45Ah nice battery.
Otto
forest
From wikipedia : "In the normal mode description of Schumann resonances, the fundamental mode is a standing wave in the Earth-ionosphere cavity with a wavelength equal to the circumference of the Earth. This lowest-frequency (and highest-intensity) mode of the Schumann resonance occurs at a frequency of approximately 7.83 Hz, but this frequency can vary slightly from a variety of factors, such as solar-induced perturbations to the ionosphere, which comprises the upper wall of the closed cavity."
I watched Don Smith videos and found embarrassing simple theory :
What if Earth is unipolar dynamo ? We know that unipolar dynamo is producing large current at low voltage.What if that 7.83 Hz is nothing else but electron standing wave around globe ? IF that's so simple then all what is needed is higher harmonic of 7.83Hz DC PULSE to excite them and cycle back to 7.83Hz. Ambient background cycling is where you have useful energy.
wattsup
@otto
OK, I will try that but only tomorrow night and report back on the week-end. I understand what you are saying about the 5khz and I will see this during the weekend. I can even put another frequency generator on there to make two frequencies to see the effects.
I put up a short Video 8 here;
http://www.youtube.com/watch?v=folknUfAz00
Actually someone sent me an e-mail asking what is required to light the bank of LEDs right off the Pulse Generator to have a base line to compare it with the last Video 7.
So my pulse generator was set at the best brightness being at 1.54mhz, 50% duty and the amplitude was at maximum 16.5 volts. On my volt meter I could only see 2.325 volts going into the LEDs at 43.5 mA (milli-amps) and this is in a closed connected scheme. Compare that with the open pulsing and only 9.3 uA (that's micro amps) to get the same or more brighter light. I don't really know how to calculate the real power used because I am on an open ended situation so how do you measure the voltage? The PG was at 16.5 volts but we can see this is not the voltage getting into the circuit because it is open ended. lol
@otto
For the coil, all you need is a length of two wire power cord with stranded wire (not one conductor each). My coil has only 5 1/4 turns.  Then put your positive of pulse to one lead then the negative of the battery to your other lead but on the other end of the coil. Then just put any wires around or even inside the coil and put an LED on it. Then tune the frequency for the brightest lighting.
