Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
bw
Right-on Giantdude
I gotta wonder what happened with him.  News everywhere in Feb.'08 then not a word since.
check out this thing  http://www.aquapol.co.uk/index.php?go=home
click "products"  then click "advantages"   This has been around since the '80's.  Don is right.
Sometimes it is looking right at you.
energy is everywhere, in the water(googe Masaru Emoto), air, earth, space, etc.   There are
likely many ways to harvest it.
giantkiller
Quote from: bw on December 03, 2009, 12:56:06 PM
Kinetic 'Shock and awe'.
I have Don's ring wired up from the spreadsheet I made. I have an NST @ 38khz, 6kv sine.
What I have to put together now is a sine channel from my Keely controller into a varister/microwave trafo supply to boost it up then into the ring. This is the way I get a HV sine wave of variable frequency. I can then test how close my specs are to the NST freq. and Don's specs into the spreadsheet. Setting up a harmonic resonance test. The missing spec I didnt put in was the distance from the far end of the secondary to the start of the feedback windings. Don found this point with a neon light. But that is only seven windings so it can be rewrapped at the appropriate place. This position is based on the resonant place of the incoming frequency and of the tuned primary/secondary resonance. The feedback pumps it at the right place of the cycle. So I build a bigaxx magnetic spreadsheet with one hand rule.
--gk.
giantkiller
The reason for the square pulses was to effect the copper at very high speed to reproduce the spark gap in electronic means. A bunch of us have succeeded at that. That was the intro into electrostatics. Now the HV sine gives the electrostatics the umph with one frequency. The squares are not rythmic enough to get a smooth harmonic resonance across the circuit as Don Smith points out. With 2 low impedance coils sitting close to each other the spacing gives storage. That is the capacitance. Now the configuration is setup as a lc tank with 1 wire and 1 frequency. The resonance creates the high impedance so the coils don't appear as shorts. As the setup that creates the magnetic field is hit at the right time the swaying occurs. The Bloch wall is moved to and fro in some units. In others it is held constant and large which creates the spin. Look at the field in the Bloch wall (even Ed Leedskalnin shows it on his Sun Clock). And still in others it is broken and healed.
The secret is to move the Bloch wall, spread the Bloch wall and let it snap back, or put perturbations on the field to cause harmonic overload. These things have plagued EEs for decades and corrupted their circuit operations. Too bad. The tidal waves of energy were crashing around them all the time..
--Giantkiller.
otto
Hello all,
@IS
you have my full respect because your a hard worker and youre showing - sharing!!! I mean it!!!
But your posts here are a little bit.....you have to much .... ( dots) and to much huuuuuum.
Try to make posts so they look "nicer", to say it in this way. You can even post your theories, if you have because NOBODY can say your wright or wrong. Only the people who made a working device can say somebody is right or wrong with his work or theory!
Have you EVER seen that I said  to a poster that he is wrong or .....NO!
About knowledge in this new technologies we dont have to discuss because as I know we have here educated people and on the other hand people that dont have any education. Im in the middle of this.
Has anybody of the high educated people found the TPU solution?
Trust me, the answer is NO!
You could read a lot of theories but they ALL missed the point because the TPU uses a well know effect but this effect was never mentioned or if mentioned, nobody has wasted his time to thnk about it.
So, what I wanted to say is that you all have the same chance. Educated or not!!
I hope I dont bother to much the members here.
Otto
Reisender
Otto, here is the picture!
I think that this configuration produces 3 rotating magnetic fields. 3 Tornados!
