Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
h2ocommuter
I got out my Gauss meter out again today and worked with the video and utube setup and things are coming along fine.
The most I have been able to accurately find  consistently is .25 mG; 25 gamma. that is actually all I need to get 240 V RMS.
I stumbled around for an hour before figuring out how I found the 100 amperes. yea it is still there and I doubled my acceptance of the readings I got before on the Hz readings.
Let me step back a bit here, I have contemplated Tesla's patents too, I think it is important to cite that he did not have the need like we do today with having the exact type voltage bulbs specifically. I am kinda thinking if he wanted to pump out 100 volts at 3KHz. to operate X bulbs or motors or equip well he could just tune his equip at will, and do it.
  I went to my shop today and picked out various bulbs with different voltages and such, along with spark plugs and things to stimulate my thinking processes. I think about the amount of energy I need to discharge with them. and what kind of voltages I will be getting with various settings, and capacitors.
to me what I think is happening is "Let alone how I am getting the 50k Hz  and 100 amps, I still have to find the voltage somewhere. I may only have 45 volts I need to figure out if I am restricting the excess amperage enough to multiply the voltages or Will I need to squeeze more out of the spark gaps to get the voltages there. What if I use an airspark gap without the ground to gather voltages. I am not yet sure where I will find them but this is the methodology I am using to get the answere now that I have devoured all of Don's writings I can find.
One last thing, just like in this patent, Tesla used timing mechanism, condensers, ground, etc.  I only read the last ten or twelve entries closest to the pics. but I bet he used spark gaps too. I am absolutely positive we can find and harness this energy too.
Thinking outside the box is like when you are on deck and you see how things are working before your up to bat. keep your eyes open, find something that is there you did not know was there.
Grace be with you
forest
I had once such amperage peak measured on digital and analog voltmeters. it was only when radiant wave was riding on top of 12 DC in opposite direction.It was however not usable in common sense - once shorted in closed circuit it simple dissapeared without doing any work. Something is missing
h2ocommuter
Yes , that scenario is one of the hidden things.
The clamp bounces around 20 amps on DC setting on the end of the L-2 and closer to the windings it is higher.
On the AC side it will be about 50 amps at the end of the wire and closer to the windings it will go up over 150 amps.
I am not going to hope for everything with the L-2 alone. and the adjusting capabilities of L-1.
My electrostatic voltmeter won't pick up anything yet.
and my Gauss meter will just barely hold .3 mG
Reading the last patent posted here page two the first # 5 states, if you don't get it right, "even though you have all the parts" it will render the unit worthless.  "high capacitance values, discharging at required freq.  a ground for neg charge and a radiant energy collector for positive charge.
These things are the same things we are working with. Nicola found the magnetic resonace in the natural ambient background. Don says we can manipulate it with freq. pulsations of our coils.
I love Don's statement about how he described this extra energy he develops in the units he built.  It is what is there!
I am going to visually show the incomprehensible relationships with the pots on the plasma globe in the videos because it has a quandary of interacting variables when you apply an L-2 and meters to the normal plasticine accepted view of the plasma globe.
you will notice various anomalies with the adjusting pots, where they act like their damaged. On the contrary I believe what is happening is they are finding resonance at different wavelinks. There I will show areas of high resistability to change and suddenly push past these areas while adjusting.
There may be two three or four variable visually taking place at any given time when looking at each various meter. these standard accepted variables move in exponential relationships to one an other at times..
Eric Dollard has a nice video about building a calculator, where he uses visual and other methods in examining the outcomes of various component arraignments.
There are more things happening here that I can explain right now.
Looking for what is there!!
Seek and yea shall find . Knock and the door will be opened.  Steel sharpens steel.
bw
Right-on H2Oc    seek & find
Tesla's patent 685957 on the second page line 55 states that the opposite terminal of the condenser is connected to the ground WHICH MAY BE CONSIDERED A VAST RESIVOR OF NEGATIVE ELECTRICITY.
In this same patent Tesla indicates the importance of the capacitor(condenser)  he says the power is in proportion to the size of the insulated collector plate.
I did notice on the 1996 Tesla videos of Don that at some point after the first demo run he unscrewed the ground wire and I believe it was still disconnected on video #19 when the bigger bulbs were installed.  The unit still worked quite well but the guy with the bulbs stated the voltage was a bit lower.   I gotta wonder if this was due to the ground wire not being connected.
My new plasma ball should be here before Christmas, maybe you guys will have found the last puzzle part by then and I can just call the power company, thank them for their service these past years, wish them a merry Christmas, and ask how soon they can move those ugly power lines and poles from my land.
sparks
  Tesla discovered the photoelectric effect.  A photon can be absorbed by an atom and overcome the binding energy of the electron to the atom.  The electron is then ejected from the atom.  The plate metal will go positive and want the electrons back bad. The electrons if made to drift away from the plate via orientation of magnetic field lines relative to the photocathode then a more efficient conversion of radiant energy to electrical energy is possible.  Especially if the electron get the hell out of there circuit is used to feed the other side of the capacitor.  Then you need to exploit Faraday's laws of induction which basically say the faster you change the magnetic field about a conductor the higher the electromotive force emitted from the conductor which should come into play when you discharge the capacitor.   You will have to use energy from the cap to saturate the core of an inductor but you will not have to use much to collapse it.  The collapse mother nature does for you and quite rapidly.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
