Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
h2ocommuter
Quote from: MasterPlaster on March 03, 2010, 10:55:05 AM
Wattsup,
Ahhh, bucking A. I thought I had seen it somewhere else before:
MP,
That looks like a Stanley Meyer schematic, What I find interresting here is only one part of the system opposite the bucking coil is the left handed wound coil on the flow through side.
This must be an important observation.
wattsup
Wattsup, Ahhh, bucking coil. I thought I had seen it somewhere else before:
Yes that looks like a very interesting coil diagram. It is strange enough to see that a toroid coil should keep the field inside the core, but in bucking method, you have two ways acting at one time. The coupling via the core and the coupling via primary to air to other pickup coils that could be placed near the coil. Not to make transmission of electricity but to simply have the  bucking field move the north/south over the pickup coils to get extra power output without hindering the pulses.
@GK
Is that center toroid wound on a teflon plumbers tape reel. I have one like that but I also put a horizontal wind inside the reel. lol
If you want a preliminary way to look at your coil/toroid relationship do this.
On the outer coils take each coil and put a low voltage LED on the ends. Then put your center toroid in bucking mode and connect the two end wires to your pulse generator. Set it at 10% duty - square wave and try and find the frequencies that will light up your led(s). Then try with the center toroid placed sideways and check again. This will give you some real revelations on what them coils can do, the angles best suited.
You can even try some other schemes like putting some of the outer coils in series or even pulsing the outer coils and putting a LED on the center toroid, just to see what it does..
One thing when you are pulsing your center toroid, you can try to take one of the wires of the outer coils and pass it over the center toroid. I have found in certain builds, this is the only way to get some effects.
I am now always using leds on my coils because using voltage meters and scopes can give wrong impressions because they do induce some energy into the coiling. But by using low voltage LEDs, you see exactly what is going on, when it happens and you can hold the position and play around and see exactly the energy relationships. For me, at this moment reading voltage and amperage is not more important then getting the right north/south coupling angles. Sometimes one degree and you are totally off the mark.
Video soon. Just got my camcorder back.
giantkiller
Thanks guys.
I was trying to remember back if the center toroid was covered anywhere at this technical level of need. If not then Wattsup and I are the only ones covering this? And at this late date?
I included the patent 5565835. Look at section 40 on down. This seems to fit especially with what Wattsup just said about the external and internal field.
I wound that new toroid last night and was not thinking. I can put a horiz copper core in there. Only need 15 feet. This would then match the patent. I had to wind this new one to get the bucking in there. Or what is the difference if I use my previous ones even tho the windings are going the same way. I could just back pulse one of them. This is a different geometry.
I will use the LEDs as a 1 pixel indicator and an EGA monitor as an field scope. I have been waiting to pull this out and use it! The EGA will give a horizontal plane display and the Led will provide a 3d reference!  8)
Those are the new ratshack spools. Thicker than plumber tape spools. :)
MasterPlaster
Quote from: giantkiller on March 03, 2010, 01:00:53 PM
I am watching from the balcony with great interest. And perhaps the other 5 people who downloaded
the patent you enclosed.
There is an accompanying patent with that US5565836.
I got side tracked reading patent US1691699. Highly recomended for those who like way out ideas.
For those not familiar with the picture I attached in my previous post, look at
http://www.overunity.com/index.php?action=dlattach;topic=3079.0;attach=12657
P.S. GK, Test your speaker wire to make sure it is not ferrous. I got some cheap speaker wires
like that and they are attracted to magnets!
h2ocommuter
That makes me feel much more at home with you guys, I have studied this stuff much and have a huge amount of SM pats. read so many of them...  This particular circuit I have studied so much in the past I am enormously glad to see some putting the values where they should be.
One point of ref..  I have used a magnet to relinquish a spark manually. This works superbly as you all probably agree with.
This circuit where the bucking end is "not the pulsing side", may be the magnetic quenching device. this circuit is in a black box compartment. Thus the signal is externally controlled.
I have lost thousands of pages of SM work with this old computer that may be recalled if anyone does not have the Black box diagrams I am referring to.
This also is the coil that controles the whatchamacallit. mind plug
see ya
h2ocommuter
