Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
giantkiller
I don't mind lurkers.
I see no comment about the sound on the video. Did everybody miss this one? I think so!
You can hear the bucking! I will now take a very extended bow to the audience...
Now lets get real serious...
What if....
Two counter pulsed rings facing opposite and each produce the comp field. Use that effect to pulse the center bucking build that Wattsup is mentioning. The comp field is much higher in amplitude than the input voltage plus little current.
In reproducing Wattsup's BFpancake and bucking mag amp tests I have seen how easy it is to conceal the magamp in a small confine plus this little device, the bucking toroid, really does amplify. SM's bucking toroids are all the same unit. Obviously it is the real deal like Wattsup said.
Now with the opposing comp fields producing a greater magnetic force it produces a really compressed tight field between the 2 rings that snaps like electrostatic discharge due to a very finite, and very pronounced, strong Bloch wall. This snap represents a high speed discharge and we know the reaction of coils to that. That snap becomes our striker that rings the bell. That bell emits frequencies to the outer rings or compounds into the center secondary of the bucking toroid.
The bottom line is to produce a Bloch with a lot of magnetic pressure then use that strong force as our magnetic bias. The strong the Bloch wall then the stronger that force equaling atomic matter or atomic/subatomic control.
And when we release the Excessive Bloch wall pressure? Mother nature takes over and puts the system back to equalibrium. And that can be read/captured also.
Otto stated 'No magnets in the TPU'. And you know what? He couldn't be more correct! The Bloch wall is to hard to modify. It is set in stone. But in Ferrite, we can produce it and alter it significantly. And this is the key!
I am still going to wrap an iron core one this weekend with the 2 layers like Wattsup said.
This is going to be a very amazing weekend.
giantkiller
What if...
The coil pictured is the bucking toroid.
otto
Hello all,
@gk
hopefully the SOURCES are connected to the coils!!
Otto
giantkiller
giantkiller
I have used 1 pulse to both but pulse b has gone through an inverter. Check out H-bridge circuits for motors. Obviously? Don't know if you have been down this road.
I used Motorola Sensefet devices before for load overdrive/shutdown.
Jason and I talked about the shoot through currents. A delay or similar probably needs to be instituted since I am driving all four legs actively. I will see. I am using IGBTs and IRF840s.
I still have to set this up. Been on another mission. Check the TPU electricity thread.
